Hi
I’m thinking of changing my frame which will probably mean going to boost rear.
I have two sets of wheels that are currently 142x12 rear and would be happy to use either on the new frame.
One set is Mavic XA Pro Carbon 29er and the other has Chris King hubs.
Does anyone know if boost adaptors are available for either of these wheel types?
I’ve found adapters for Hope, DTSwiss and I9 but not the above two.
I’ve done some googling but what I do find is confusing.
Steve
Just buy the kit which is two 3mm axle spacers and brake disk spacer (assuming 6 bolt). Wheel make shouldn't matter.
Ok
Make? Company? Link?
Steve
Ebay for a few quid. Just type in boost adapters into the search. They worked fine for me, make sure the disc adapters come with long bolts.
Most importantly get bright coloured wheel spacers. You'll find out why if you take a wheel out on the trail.
