Rear axle compatibi...
[Closed] Rear axle compatibility
[#4485338]
If I bought one of these
and stuck it through one of these
would I be able to fit it into this, a Singular Swift rear dropout?
Thanks for any help.......
Posted : 22/10/2012 10:23 pm
yup
Posted : 22/10/2012 10:24 pm
If the swift has standard dropouts then they'll take either QR or 10mm bolt thru. So it depends what size those bolts are...
HTH
Posted : 22/10/2012 10:27 pm
Lovely, thanks for the quick response - I was just concerned that the diameter of the dropout wouldn't be sufficient to fit a 10mm axle. Ta
Measure 🙂
Posted : 22/10/2012 10:33 pm
Good idea...
Posted : 22/10/2012 11:09 pm
"diameter of the dropout wouldn't be sufficient to fit a 10mm axle"
If it wasn't, what would it fit?
rear QR use 10mm axles
Iif it bothers you, afaik, the superstar 10mm thru axle is steel and heavyish. JustRidingAlong has the DT swiss 10mm for £30 atm and 49g
Posted : 23/10/2012 12:47 am
