Reaching chainstay ...
[Closed] Reaching chainstay caliper bolts...
[#9995006]
The new Boardman CX has flat mount on NDS chainstay.
The curve of the seatstay means you can only reach in at a certain angle with a ball-ended hex.
With the wheel in place means I have to put the tool through the spokes.
Wharra faff and makes simply altering a caliper position much more challenging.
Anyone else got another frame with similar, or is it just my Boardman?
Posted : 18/05/2018 1:19 pm
It’s not just boardman that have that problem.
And not found an easy way yet
Posted : 18/05/2018 1:50 pm
I've got a micro Bahco set, it has a small ratchet driver that takes 1/4 hex bits.
Sounds perfect for this type of PIA job.
This is the one, can't remember where I bought mine.
Bahco 2058/S26 Ratchet Socket Bit Set
You can also buy 1/4 square drive wobble extensions, for socket set. Give about 15 to 20 degrees offset.
Posted : 18/05/2018 1:59 pm
Hmmmm, as I discovered today though, multi tool doesn't work, so I need to carry an alternative with me..
Posted : 18/05/2018 5:39 pm
Topeak micro ratchet mini tool was my solution. Can get mini chaintool for it as well.
Posted : 18/05/2018 6:27 pm
I'm intrigued by this, as my flat mount calipers (road bike) are bolted onto the chainstay from below, and are, therefore easy to access.
Any chance of some pictures, so I can see what design to avoid, in the future?
Posted : 18/05/2018 7:13 pm
The new Boardman CX
I pretty much found this with the 2014 CX! Along with it's unique m4.5 rack eyelets that needed rethreading and the rather strange internally lipped BB shell.
Posted : 18/05/2018 9:15 pm
Had a look at one, in Halfords, over the weekend.
They've done that crazy thing where the frame is flat mount, but the fork is IS/post mount.
This means buying one post mount and one flat mount caliper (fiddly and expensive) or using an adapter to mount a post mount caliper to the frame.
Come on, bike companies, make your mind up!
Posted : 21/05/2018 7:43 am
Just use a stubby screwdriver with the hex bit for 90% of the tightening... then you only need a few awkward turns with an allen key or micro-ratchet AFTER....
Posted : 21/05/2018 8:36 am
Reminds me of the front mech on a pro flex
Posted : 21/05/2018 10:12 am
