Re-rim, ERD toleran...
[Closed] Re-rim, ERD tolerance question
[#9431700]
If im reusing spokes and have a rim with an ERD of 528mm, theoretically with standard or longer nipples etc what rim size can I get away with?
Posted : 12/07/2017 9:58 am
Anyone for the late shift?
Posted : 12/07/2017 11:19 pm
 nonk
Sort of depends on the original build
Did the builder go a bit long or short or is it bang on
and which way relative to that that you are going with the new erd
What rims are you using ?
Posted : 12/07/2017 11:29 pm
Std specialized roval dh rims. Trashed after a few runs would rather run 721s which are 535 as I have a stack
Posted : 12/07/2017 11:55 pm
 nonk
That's gonna produce a difference of about 3 mm in spoke length
So You might be ok but as I said if you have a build that's a bit on the short side you might not
Have a look in the rim to see how far the nip is wound on to the spoke
Posted : 13/07/2017 12:07 am
If you’ve got 12mm nipples you could swap to 14mm to get you 2mm. Haven’t worked out the numbers myself so can’t confirm 3mm is all your going to need though.
Posted : 13/07/2017 7:07 am
Spokes typically come in 2mm increments, so +/- 1mm after rounding is accepted norm. If the rim ERD is 3mm bigger, then 14mm nipples will give you 4mm, so you'll have a little bit of spoke showing through the nipple. If the rim ERD is smaller, it should be OK as about half of the spoke/nipple thread is redundant anyway - thread loads only taken by about 3 turns.
Posted : 13/07/2017 8:21 am
