re-greasing dmr v8 ...
[Closed] re-greasing dmr v8 pedals
[#2703286]
evening.
what alternatives to dmr's own grease could i use to regrease my pedals? would finish line teflon grease be suitable for this task at all?
Posted : 29/04/2011 8:52 pm
yep that's exactly what i use on my v8's and v12's. It's ideal. You can either get a grease gun the screw directly on the tube or just squirt some into the supplied syringe and use that. Put a load in though. I do mine until it comes out of the ends a little.When v8's are new they have hardly any grease in them at all.
Posted : 29/04/2011 8:55 pm
I refil the syringe with it too, I could tell no difference between it and the dmr stuff with regard to performance.
Posted : 29/04/2011 8:59 pm
yeah i was gonna refill the syringe with it if it was suitable.
cheers chaps!
Posted : 29/04/2011 9:00 pm
V8s are disposable pedals. Use them till they're gritty, scrap them, buy another pair.
Posted : 29/04/2011 9:08 pm
Castrol LM or CL.
V8s get gritty? Mine never have, but then I did rebuild them correctly before I fitted them to bike (filled them with grease completely, adjust bearing preload correctly), and I do top them up with grease every now and then.
Posted : 29/04/2011 9:11 pm
bassspine - Member
i'm not disagreeing with you, but...
they're easier to keep alive for longer than almost any other pedal.
and they're waaay cheaper than almost everything else.
much under-rated.
Posted : 29/04/2011 9:26 pm
I'd agree with under-rated - don't get me wrong, they're great value. Like kona jack sh1ts too.
Posted : 29/04/2011 9:48 pm
bassspine- true enough, but they do have a grease port and there's plenty of life in mine still, they just need regreasing and i have none of the dmr stuff left. a quid or so's worth of grease will get me another summer out of the pair i have.
Posted : 29/04/2011 9:58 pm
Any grease will do I use castrol LM
Posted : 29/04/2011 10:02 pm
Does LM go off? I'm still gradually working my way through a tub my dad bought in about 1978
Posted : 29/04/2011 10:19 pm
I also use Castrol LM, and the original syringe.
Never had any probs with my V8's, had them for about a year.
Posted : 29/04/2011 11:04 pm
V8s need regreasing?
Posted : 29/04/2011 11:27 pm
v8's are designed to be rebuilt. Just rebuilt and repainted a pair of mine which are 10 years old.good as new now,brilliant pedals ( and also v12's too) cost me about £8 including terror pins (and bearings)
If you full the v8 up with grease it shouldn't get gritty, unless the bearings wear lots.
Posted : 29/04/2011 11:34 pm
