Just stripped down the freehub on my crossride's. Anyway i was wondering if it's better when rebuilding it to go for the standard pack it full of grease strategy? Or to keep the grease in the freehub area to a minimum so as it doesn't stick the pawls?
All opinions welcome.
Keep it clear of the pawls I think.
Right further to my question. Having done some research around the web i've found an answer & the answer is for mavic hubs/freewheels there should be no grease put anywhere near the freehub at all. Just mineral oil. I found the following to be of help [url=
1[/url], [url=
2[/url], [url= http://www.tech-mavic.com/tech-mavic/technical_manual/data/mavic_tech.php ]Mavic technical website[/url], [url= http://www.tech-mavic.com/tech-mavic/technical_manual/data/docs/products/2_16.pdf ]technical construction PDF[/url]
Hope this may help someone else later on that's looking for the same info. As it took me a while to find all of those links.
