Ragley Turning Circ...
[Closed] Ragley Turning Circle freehub removal - how?!
[#8416170]
Has anyone tried to service their Ragley freehub, mine is one an off the shelf Bluepig. They certainly arent like Hope, in that the freehub body doesnt just pull off. I've removed the spacers with 2 x 5mm hex keys, I can knock the axle loose, put the freehub wont shift.
The best help I've seen online is a video showing a Vuelta hub, which is what I think the Ragley hub might be, but that talks about using a 6mm hex too, but there's no where on mine for a 6mm to engage.
thanks
Posted : 25/03/2017 4:35 pm
I would imagine there's a hollow hex bolt securing it to the hubshell. Maybe 12 or 13mm?
Posted : 25/03/2017 4:41 pm
Thanks - I'll look again.
A bit of further research and I think it might be a Nukeproof Generator hub, rebranded. If so, it should just pull off...which it doesnt.
Posted : 25/03/2017 4:46 pm
