ragley mmmbop bb ax...
[Closed] ragley mmmbop bb axle length
[#2072648]
going to fit a square taper bb and a truvativ isoflow crank, do i need a 68/113 or 68/118?
Posted : 09/10/2010 11:07 pm
Newer mmmbops are 73mm
Posted : 10/10/2010 12:04 am
axle length depends on what crank you're using and if you're fitting an e type front mech etc
Posted : 10/10/2010 2:38 am
[u]axle length depends on what crank you're using and if you're fitting an e type front mech etc[/u]
Exactly that is why i ask the question in the first place granny ring!
I am looking for the answer, not confirmation that i needed to ask the question in the first place!
It's as i described earlier with a standard mech.
Posted : 10/10/2010 11:10 am
only trying to help....it was a tad late for me, I missed the cranks bit and you never mentioned the front mech... 😀 at a guess it'll be 113mm, I used a 118mm on my genius frame with e type mech, that was an octalink crank though.
Good luck.
Posted : 10/10/2010 1:52 pm
