I have hardly any experience of headbadges other than briefly looking at them. Do the Ragley ones come with double sided foam tape, some rivet thingy or a little spiky doodah that you wallop into a drilled hole? Or something else?
I like the look of them but don't know what I'll need to do to my frame to put one there.
Cheers 🙂
Yes, double sided foam tape, one side already fixed to the headbadge. Suggest using some masking tape above and below where it'll be fitted to mark out the position before fixing. Otherwise you'll be faced with the problem of how to remove and refit it when someone points out it's skewif. Grrr
Cheers, that's a good point about the masking tape!
