Ragley Blue Pig pic...
[Closed] Ragley Blue Pig pics..
 rob2
[#468677]
Anyone taken a look at the steel Ragley... http://www.shedfire.com/
Anyone/Brant have an idea on weight for the steel version?
Posted : 13/04/2009 7:56 pm
Stays look really long, is it a 29er?
Posted : 13/04/2009 8:00 pm
26" wheels and same geometry as the Ragley Ti.
Posted : 13/04/2009 8:09 pm
what fork length is it designed for?
Posted : 13/04/2009 8:10 pm
Dont like the finish 😉
Posted : 13/04/2009 8:14 pm
Knowing Brant's marketing methods, it'll fit all of them.
Especially yours.
Whatever length they happen to be.
Posted : 13/04/2009 8:18 pm
one fourty forks.
Sixteen and three quarter back end.
Posted : 13/04/2009 8:43 pm
 ton
looks a bit ermmm thin..... 🙄
Posted : 13/04/2009 8:49 pm
looks ****in lovely !
Posted : 13/04/2009 8:54 pm
38mm dt. 32 to 34mm tt. Skinny rear stays. Braaap.
Posted : 13/04/2009 9:02 pm
 rs
Braaap.
Posted : 13/04/2009 9:06 pm
Bolt on cable guide samples have landed. Pics soon.
Posted : 14/04/2009 12:02 pm
Cool name Brant!
Posted : 14/04/2009 12:13 pm
"Brant" is a terrible name
Posted : 14/04/2009 12:15 pm
It's a rock climb in Wales you know - http://www.ukclimbing.com/logbook/c.php?i=2266
Posted : 14/04/2009 12:22 pm
What's the extra bit connecting the BB shell to the chainstay for?
Is that for making sure you dont leave any mud behind on the trails and take it home with you? Looks mudtraptastic.
Posted : 14/04/2009 12:32 pm
Braaap.
No 2-wheeler goes 'Braaap' unless it has an engine in it.
Posted : 14/04/2009 12:35 pm
 wors
unless you put a plastic drinks carton between your tyre and forks 😀
Posted : 14/04/2009 12:40 pm
.... Thus trying to emulate said engine, but failing miserably.
Posted : 14/04/2009 12:42 pm
Still not sure i understand the need for bolt on cable guides, surely they cant be any lighter/stronger/neater/cheeper than normal ones?
Posted : 14/04/2009 12:43 pm
No, but they can be removed if you run it SS, I 'spose.
Posted : 14/04/2009 12:46 pm
Yeah David. That's exactly why we did it.
Oh my aching ribs.
Ahem. Right. Any mud that's arrived at that point (by virtue of the ridiculous amounts of radial clearance on the seat stays) won't get trapped in that bit, as that bit is already shielded by the front mech.
So the front mech will catch it, and there isn't a lot I can do about that to be honest, well, except the fact that the mud clearance at the seatstays is slightly less than the mud clearance at the chainstays, so that the big stuff gets scraped off up top, rather than down below.
Posted : 14/04/2009 12:51 pm
It came about from people asking about Rohloffs, and SS and all sorts. And the fact that a triple top tube cable guide on a ti frame costs a fortune, even before you've welded it on. And I was never very impressed with the fact that you have to weld bits onto ti frames "just" to guide cables.
Ti cable guide - $7.92 even if you buy loads - http://www.paragonmachineworks.com/product_details.php?productId=248&categoryId=4
And once we'd done it on the Ti frame, we thought it would be nice to do it on the others. We still might not. Got to look at options. I like it though. Got my samples through today and when I get 5mins I'll shoot some pics.
Posted : 14/04/2009 12:54 pm
brant whats the weight of the steel version?
Posted : 14/04/2009 12:55 pm
They've not told me yet.
I thinking mid 5's right now.
Posted : 14/04/2009 12:59 pm
Brant, you may have guessed it already but I confirm I WILL be buying one of these!!!! 😀
Posted : 14/04/2009 1:06 pm
Ho would it ride with 100 - 120mm forks?
The headangle would obviously be a degree or two steeper but its slack anyway, but would the bb/front end be too low?
Posted : 14/04/2009 1:10 pm
It'd be OK David. BB isn't "low" so that's not a problem. As I've said before - all forks are about the same length when they're bottomed out 🙂
Posted : 14/04/2009 1:15 pm
 tang
is that a 'fettlers elbow' chainstay?
Posted : 14/04/2009 2:01 pm
Blue Pig??
any connection to the drinking hole by that name down Hebden (ish) way (Mankinholes or somewhere similar?)
Posted : 14/04/2009 2:16 pm
Brant, you need a page putting up that explains why the brace isn't a mud trap and why you're (maybe) going for bolt-on guides, so you don't have to explain [i]every[/i] time someone mentions the frames!
Posted : 14/04/2009 2:21 pm
unless he is using it to develop a muppet filter 😉
Posted : 14/04/2009 2:23 pm
Im not bothered about mud clearance as I live somewhere where the trails are still good all winter, however my frame has double the clearance of my forks, especially my older ones in the shape of a nice Italian 'M'.
Fugly gusset twixt Top/down/head. Needs a nice smoothly blended one.
Posted : 14/04/2009 2:25 pm
yes.
Love it.
If you can see that when you're on the bike, you've fallen off it..
I have plans for all sorts of head tube area things, but perfectly happy with that for now.
Posted : 14/04/2009 2:54 pm
Blue Pig??
I think in this context it refers to the descent that leads to the pub? To be honest I think I'd prefer to ride that on a full susser. 😉
Posted : 14/04/2009 3:04 pm
you've not lived.
Posted : 14/04/2009 3:15 pm
Brant, I can do like flat tabletops. Like.
Posted : 14/04/2009 3:20 pm
mega.
Posted : 14/04/2009 3:27 pm
brant - Member
you've not lived.
PMSL...the way rides should be.
The first few times I looked at the frame i liked the gusset around the toptube/ downtube area. But the more I look at it the more I have to agree with Scruff. Just looks a bit odd. Have you looked at maybe a cnc'd brace. Something similar to the cnc'd brace on the Airborne Black Widow.... Just a thought....
Posted : 14/04/2009 3:30 pm
Brant, this wonder-stay youve designed, will it clear chaindevices and such things? Just i had to take a file to the chaindevice fitted to my 456SS to get it to sit against the ISCG mounts.
Posted : 14/04/2009 3:31 pm
If by "you've not lived", you mean "I've not nearly died because I rode a horrible abortion bike down a bumpy off-road track" then yes, I've not lived. Now when's the Clunker Classic this year...
Posted : 14/04/2009 3:32 pm
No (with good reason). Anything CNC'd in there would be just not right.
Yes.
Posted : 14/04/2009 3:37 pm
Where are we going to be able to try before we buy?
I love the look of it but I've been caught out before when buying a bike from reviews to find it doesn't suit my (NON) style.
Posted : 14/04/2009 3:53 pm
I am liking muchly the disc mount 🙂 I am not liking muchly Toby's haircut, make haste with yonder clippers!
Posted : 14/04/2009 4:01 pm
