Evening, I've fitted my RADr cage successfully, but what are the two small black studs for that came loose in the packet?
The studs go between the cages.
There's two threaded holes in the out cage.
Let all the air out of your shock and compress the back end fully then see how short you can make the chain. Looks like you can go a bit tighter but just check when the bikes compressed.
Just looking at your first pic.
You sure you have the spring assembled correctly?
The cage should pull back much further than that.
[url= https://farm9.staticflickr.com/8662/15792102697_5ecdac4a1e_z.jp g" target="_blank">https://farm9.staticflickr.com/8662/15792102697_5ecdac4a1e_z.jp g"/> [/img][/url][url= https://flic.kr/p/q4uDWH ]IMG_20141208_192430153[/url] by [url= https://www.flickr.com/people/18504429@N00/ ]multispeedstu[/url], on Flickr
Did you watch the vid on the rad web site I found it very good
Yes, I watched the vid. I'll go off and check everything over now and get back to you.
Right, all sorted. Stu, you were right, I had not got the spring correctly in place. Thank you very much for your help. Now to go ride the thing and see if it was worth it over the stock Zee mech...
Definitely improved the shifting on my XT mech, I do need to lose a couple of links from the chain though. Great little addition
Stop buying own brand greek yoghurt.
Total is Greece's favourite for a reason!
Flippin' runny nonesense. If you can turn the pot up and it runs out, it aint greek.
[img][/img]
IMG_20141208_192430153 by multispeedstu, on Flickr
Johnny Five - he's alive!
(Heads over to the Radr site to see what this is all about...)
