Raceface Team Beari...
[Closed] Raceface Team Bearing Replacement Problem
[#11740351]
Swapped in a spare new BB into my Crush this evening but can't seem to find a replacement in the UK. I appreciate I can get a Hope (though they seem in short supply)  or Uberbike but thought I would change the bearings in the RF BB as I had some spare 6805s to hand.
I put the new bearings in (1 Uberbike branded and the other Brand X) but both are notchy.
Can you change the bearings in this BB, if so where am I going wrong ?
TIA
Posted : 07/02/2021 11:22 pm
Yes you can
How did you press in the new bearings?
Posted : 07/02/2021 11:48 pm
I used a Hope BB installation kit to tap in one side and some sockets and a bearing press tool on the other side.
Not the official tools.. but.
Posted : 08/02/2021 12:00 am
Should have worked so long as you were pressing on the outer bearing race.
The Hope bb tool is the method I usually use or press the bearings into the cups in a vice using the old bearings as a drift.
Posted : 08/02/2021 11:57 pm
How long have you had them spare? If they had never been used in anger and you had them for a long time they may have picked up some spots of corrosion. Sometimes there isn’t a lot of grease in these things as new - I always use a craft knife to pop one of the seals off and press a bit more grease in. To be honest you might still try that...might help in short term at least.
Posted : 09/02/2021 12:06 am
