Raceface next SL wo...
[Closed] Raceface next SL worth it?
[#6153960]
For the weight weenie..worth it? To go with 1x10 or 2x10
Or just go XTR which is not that great weight saving against SLX for price value.
Posted : 30/04/2014 8:28 am
XTR same money for more weight?
I was advised to skip shimano if weight was a concern really as they just don't cut it.
The missus got a set of the Next's and they are lighter than light things (even bearing XX1), proper nearly throw at the ceiling if your not expecting it. Comes with 1x or 2x spider options too. Fitting is much nicer and easier than shimano also needing only the 1 8mm allen key to do it. Looking out for a set coming off a new bike in the near future.
edit also come with normal BCD's so you can fit any rings rather than being stuck with XTR only ones
Posted : 30/04/2014 8:34 am
Cheers. Guess RF Next SL it is 🙂
I got sucked up with this weight weenie thing when i bought a carbon frame 😕
Posted : 30/04/2014 10:58 am
