Raceface atlas doub...
[Closed] Raceface atlas double chainset
[#5593004]
Will this fit my alpine frame I've just bought. 104mm bolt circle.
Posted : 11/10/2013 10:15 am
The BCD is not the important thing... If you have a 73mm BB and you have bought a 73mm BB chainset you are fine. If you have a press fit BB and you have bought a 73mm chainset then again it will fit. The only one I am not sure of is the 83mm BB shells on the bike but I don't think the Alpine has that.
You may need to use spacers to get your chainline plumb.
Posted : 11/10/2013 10:21 am
Is that a yes it will fit?thanks.
Posted : 11/10/2013 11:29 am
Read Mbnut's post again - if it's a 68 or 73mm BB shell then you should be OK (use appropriate spacers when fitting cranks to fine-tune chain line).
If it's 83mm (which it isn't) then you may struggle UNLESS the crank is for an 83mm BB shell, in which case it won't fit a 68 or 73mm shell...
Posted : 11/10/2013 11:55 am
