Do they actually fit on the QR front & back, for road bikes with no eyelets/mounts?
Bump?
Short answer... Yes
Long answer... Yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeees
Mine do 🙂
Am I late?
Simle answer: yes.
Convoluted answer: kilo man, learn to resize your photos before you put them on the internet. a 1.5 mb photo in place of a one-word answer (yes) to a question? Have a word with yourself.
Yes they do.
I'm back to the race blades now and have a spare set of longs if your after a set? They are silver
Didn't they have a recall? Early ones used to clip [b]onto [/b] the QR skewer and the new ones loop over the ends, so you have to remove the skewer completely to fit/remove? Could someone post a nice picture of their Longs removed with just the brake bridge mounting in place? I'm thinking of a set for my race bike when it moves to winter duties.
Early ones used to clip onto the QR skewer and the new ones loop over the ends, so you have to remove the skewer completely to fit/remove
The ones I have which i presume are later ones as I bought them in November clip into a mounting point which goes under the qr which you can see in the photo above, so to fit the mounting point you have to remove the qr but once that is in place to remove the guards you just unclip them there leaving the q/r alone and at the brake mounting point.
I believe one photo is worth 1.5mb of words or something like that, but the photo helpfully shows the mounting clip as detailed above in reply to another question, so it's all worked out nicely :-).
Is 1.5mb big? I'm not a computer nerd so have no idea
ChrisA - Member
Yes they do.I'm back to the race blades now and have a spare set of longs if your after a set? They are silver
Thanks Chris - I may be interested depending on what colour bike I get - I should know by the weekend.
Could we have a better white balance on the photo as well
do the QR clips work with nutted 9 and 10mm axles as well, or is the hole only big enough for the m5 bolt/qr spindle?
I'm assuming they do as it would be mad for them not to, but just checking...
Sorry to divert the thread a little but how to the Race Blade longs compare to Crud Road racers?
I'm fed up of the Roadracers always rubbing and clogging up with mud.
amedias - Memberdo the QR clips work with nutted 9 and 10mm axles as well, or is the hole only big enough for the m5 bolt/qr spindle?
just looked qr spindle only
