Race Face Press-Fit...
[Closed] Race Face Press-Fit BB92 X-Type BB alternative
[#11033299]
I’m have issues with my Race Face Press-Fit BB92 X-Type Bottom Bracket. Am I correct in thinking I can replace it with a Shimano bb like this?
Link
Posted : 02/02/2020 10:20 pm
Bump
Posted : 03/02/2020 9:38 am
I replaced my raceface bottom bracket on my Capra with a XT shimano BB, I was running aeffect cranks. I think that different raceface cranks use different spindle diameters.
https://www.amazon.co.uk/dp/B00WLFTBMA/ref=cm_sw_r_cp_api_i_32-nEbZCHXZFR
Posted : 03/02/2020 10:58 am
Which cranks have you got?
If it's an Aeffect then yes, you can. If it's one of the other Cinch cranks with a 30mm axle then no, you can't - you need to use a PF86/91 BB with a 30mm hole. These are thin on the ground - the Raceface one is terrible, I'm currently using the Rotor 4130 and it's been good but I've only had it in 6 weeks.
https://www.mantel.com/uk/rotor-press-fit-4130?spec%5B%5D=41&utm_source=google&utm_medium=shopping&gclid=Cj0KCQiApt_xBRDxARIsAAMUMu86qrJnsx5r_VmSDXSXQMNNnGUEXnt8oof7w4O6AFhIelyxZBidTooaAnsqEALw_wcB
Posted : 03/02/2020 11:57 am
 RicB
I’ve found the Race Face PF91 ok, but only if you take the inner seals off and pack the bearings with grease before fitting. I get over a year out of mine this way. Which still isn’t brilliant mind
Posted : 04/02/2020 3:01 pm
thanks for the help. To close out the thread, i ordered and fitted a Shimano XT MT800 MTB Press Fit Bottom Bracket Black 89.5/92mm. It works perfectly.
Posted : 12/02/2020 2:03 pm
