I got very cheap quill 1 1/8th forks for winter. They're fine, apart from the quill bit. So, I found a quill to Ahead adapter. Fine, but you can't tension the headset, which turned a "5 minute job" into 2 hours of bodge. So, I had to find a way to tension the headset...
Ta-da! (obviously the scaffolding comes off once the stem is tight...)
I expect I'll get an award for that.
Cheers, al.
I cant even work out what you have done??? Couldnt you push down to tension it?
So you have a quill fork with an aheadset headset and stem?
You will probably get a Darwin award.
pwew on looking a 3rd time I see what you was doing... Nice.. 🙂
Suspension forks on a pompino? /boggle/
I'm confused. Quill forks. quill to ahead adapter - ahhhhhh now I see.
what was wrong with the summer forks?
