Quill stem help
[Closed] Quill stem help
[#8016970]
I have an elderly hybrid with a 1" threaded steerer. I'd like to put wider bars on this; anyone have any thoughts what the best way of converting from a quill stem to 31.8 clamp bars is?
Posted : 25/08/2016 9:20 am
 JoB
you're mixing up your steerer and bar clamp diameters here, can you get some wider bars to fit the clamp in the existing stem?
or get a quill-ahead adapter, clamp a ahead stem with a 31.8 bar diameter in there
Posted : 25/08/2016 9:28 am
Aye, that's what I thought. Not keen to use a shim though and Google-fu is failing me - can you get quill adaptors in 1? or 1" threadless stems?
Posted : 25/08/2016 9:35 am
Just fit wider bars with a 25.4mm clamp area and use existing stem?
Posted : 25/08/2016 9:39 am
 JoB
[url= http://www.wiggle.co.uk/profile-design-quill-to-threadless-stem-converter/ ]here's[/url] a 1" quill to a 1 1/8" ahead stem one
Posted : 25/08/2016 9:42 am
Quill stems went out of favour about 15 years ago when 25.4mm bars were the norm, so chances of finding a 1" quill stem for 31.8mm is pretty remote. Quill/ahead adaptor and choice of stem and bars would be the best way to go
Posted : 25/08/2016 10:16 am
This is an old Kona Hahanna with a quill stem adaptor - works really well if a litle heavy.
Posted : 25/08/2016 11:21 am
Those adaptors work fine. I'm running them on my TT bike and a track bike with no issues - including shimming for the TT bike. Despite beautiful looks, the loss of quill stems was one of the most significant moves to proper bike fit. I don't miss them. Apart from the old school headset, you would not notice that the track bike didn't have a modern stem.
Posted : 25/08/2016 11:27 am
Stupid question about the adaptors - do they need spacers or does the stem just clamp on?
Posted : 27/08/2016 12:42 pm
No spacers required - just chuck it in there. My old Hahana has one too (not as pretty as the one up there ^^^).
Posted : 27/08/2016 1:12 pm
All set; even found a polished alloy stem (FSA Gravity Lite of all things).
The 685mm EA70 riser might look a tad odd on a 20+yo hybrid mind you...
Posted : 02/09/2016 8:47 pm
