Quicks swap Reverb ...
[Closed] Quicks swap Reverb options?
[#3547599]
I'm thinking about springing for a Rockshox Reverb, partly as it'll fit two of my bikes - three if you include a roadie, but somehow I don't think so... The obvious stumbling block is devising a way of swapping the thing from bike to bike without endless faffing.
As far as I can see, the bar lever clamp is split, so that's not a problem, it mostly comes down to the hose. So far I'm leaning towards using a set of these run along the underside of the top tube on both bikes - three clips to remove for the swap over and obviously, saddle angle to be tweaked etc:
[url= http://bbbcycling.com/bike-parts/cables/BCB-94/ ]http://bbbcycling.com/bike-parts/cables/BCB-94/[/url]
[img] &width=1000&height=800[/img]
Just wondering if anyone else has tried this and come up with a neat solution? In an ideal world RS would produce a QR mechanism at the seatpost end, but I guess that's unlikely for fairly obvious reasons - viz, why sell one Reverb when you can sell two... 😉
Posted : 10/01/2012 10:08 am
