Quickie Disc mount ...
[Closed] Quickie Disc mount adaptor question
[#476711]
LX post mount calipers are naturally 160mm at the front
Im I right in thinking that an IS to Post adaptor usually makes a 180mm set up up front? and does the same adaptor at the rear with the post caliper make a 160mm rear?
Posted : 16/04/2009 12:09 pm
Depends on the mount i think. You can get is to post for any size rotor front or rear. I've got them from 160 to 203.
Posted : 16/04/2009 12:13 pm
Aha, think Ive got it with a bit of trial and error.
the adaptors that come with the LX calipers give 160mm on the front, but less than that on the back so you need a bigger adaptor at the back to give you 160mm which if it was used on the front would give 180mm...I think 🙂
cheers
Posted : 16/04/2009 12:28 pm
Yep, rear (160mm) mount placed on the front fork gives you a 180mm mount.
Posted : 16/04/2009 1:09 pm
managed to find the shimano tech docs.
the only difference between the m585 fron and rear are the adaptors that come with it. You would have thought a sensible IS would have been to have the same relative position for the mounts from the axle centre for both forks and frames 😯
cheers all.
Posted : 16/04/2009 1:15 pm
