quick tubeless ques...
[Closed] quick tubeless question
[#7100061]
I've just refitted my back tyre (Hans Dampf) after cleaning out the almost dried out stans sealant. New sealant in, have done a short ride, all the shaking about stuff, left the wheel horizontal overnight but it's still losing air. Soapy water test reveals lots of air escaping through sidewalls. The only thing I can think of is that the new sealant is from a bottle that was originally opened about a year ago, does it go off after time? Any other pointers much appreciated...
Posted : 31/05/2015 11:04 am
I was wondering this yesterday. I have a bottle of opened Revo Sealant that I was attempting to squeeze into my sons football via a thin valve, but it kept blocking with little clots of latex. The bottles only been open a month. It would still squeeze through a bicycle valve though.
Posted : 31/05/2015 11:08 am
How much sealant did you put in? my advice would be to put 40-50psi in and spin the wheel quite a bit, or go for a short ride. Tilting the wheel while passing it through your hands seems to help too. Bloody Schwalbe.
Posted : 31/05/2015 11:14 am
If it's definately the sidewalls, then it's just a case of add more sealant and repeating the shake n bake shuffle.
I had some conti x kings that took ages to seal the sidewalls.
Are the beads definately seated?
Also, I assume you gave the Stans bottle a really good shake? The latex settles very quickly.
Leave the wheel horizontally on a bucket for a few hours on each side, with plenty sealant inside. And yes, it does go off, hence I now only buy the smaller bottle.
Posted : 31/05/2015 11:16 am
Don't scrape out the old sealant residue next time.
Posted : 31/05/2015 11:22 am
lornholio speaks wise words.
Posted : 31/05/2015 12:09 pm
Yes I did shake the bottle, I think the fact that it's old is part of the problem. Hadn't considered cleaning out the old stuff would be a factor, will leave in next time. I'll continue to ride/shake/leave horizontal. Thanks for all the replies.
Posted : 31/05/2015 12:20 pm
Have a look at the empty sealant bottle. Does it have a load of sediment at the bottom?
You really need to shake the stuff to get it mixed in before you put it in the tyres
Posted : 31/05/2015 12:56 pm
use oko linseal from your local agricultural centre, doesn't go off over time. if tyre takes a few hours to go down just keep pumping up and riding it will seal eventually.
Posted : 31/05/2015 3:44 pm
