Unscrewed the hose from my Reverb today to re-route the hose. Was as careful as possible to keep the hose end 'high' but with everything reconnected pressing the trigger no longer releases the post to drop.
Will a bleed fix this or have I borked it totally?
Posted : 24/04/2016 9:46 pm
Bleed. Will be fine, unless you also broke something else.
Posted : 24/04/2016 9:48 pm
A quick bleed should sort it
What fluid do I need?
EDIT. Found it.
Posted : 24/04/2016 9:50 pm
