Are the reducers for Fox & RockShox rear shocks compatible?
From what I gather, they both use 1/2 inch bushings, but are they the same width etc?
Was wondering if I can drop a Fox DHX air shock into a frame which came with a RS Monarch shock originally without buying new reducers.
Doubt it makes any difference, but the frame is a Pace RC405
Cheers 😉
By reducers, I assume you mean bushes? In which case, the answer is no, the bushes are different sizes.
I thought they were both using 1/2 inch bushes 🙁
I actually meant reducers though, the little top hat thingys that sit between the frame and the shock bushing. Maybe 'mounting hardware' would be a better term than reducer.
Well at least, the Fox and Rockshox shocks I currently have are definitely different - I mean the tophat bits too BTW
Ah okay, thought it was too easy 😉 cheers anyway
I wish somebody would just pick a standard size and go with it!!
