Quick pike question...
[Closed] Quick pike question about travel change
[#6946569]
If you swap a 150 air shaft for a 160 (26") do you need to alter the level in the charger.
That is all.... 😀
Posted : 20/03/2015 10:14 pm
I didn't, I followed [url= http://blahblahbikeblog.blogspot.co.uk/2014/01/reducing-rockshox-pike-rct3-solo-air.html ]this[/url] and it was pretty straight forward to be honest.
Posted : 20/03/2015 10:18 pm
 nuke
Me neither. I used guide as linked above ^ ...simple aside step 6 which is a bugger
Still, got loads of help with the thread i started... http://singletrackworld.com/forum/topic/anyone-changed-the-travelair-shaft-on-their-pikes 😐
Posted : 20/03/2015 10:52 pm
Thanks FH...
Haha.At least you replied to mine nuke...Cheers..
Posted : 20/03/2015 11:26 pm
We should start an air shaft swapping thread.
Maybe a PayPal payment refunded upon receipt of swapped air shaft?
I have a 27.5 150 and will need a 27.5 160 soon
Posted : 20/03/2015 11:31 pm
Might work for me!
140mm 29er shaft and need a 130, same parts as your 27.5 ones. Is yours new or used?
Posted : 21/03/2015 12:34 am
 nuke
When I did the swap I also followed the MBR vid just referring back to the Regularbob blog guide...
Oh and for what its worth, the trick I found with step 6 (of the Solo air travel change adjustment section of Regularbob's guide) is to have two people: one to press the black plastic seal head down and one to get in there with the snap ring pliers. You're not aiming to get the retaining ring right out initially, just get the edge of the ring on the raised bit of the seal head...it'll become more obvious when you do it
Posted : 21/03/2015 8:40 am
Ooo I could do with a 29er 130mm shaft. I have 150mm at the mo I'd swap:)
Posted : 21/03/2015 10:42 am
Tenacious Doug, currently it's 1 ride old and will probably be 2 or 3 by the time I need to change the travel. If that works for you then this might be a goer
Posted : 21/03/2015 2:18 pm
Cheers all and that's for the youtube vid nuke.
Posted : 21/03/2015 9:37 pm
