I've just received a new bike (insurance replacement through Wheelies) - Fox Float forks but no pump to set the air pressure.
Are bikes fitted with Fox Float forks usually supplied with the high-pressure pump?
Or is it left to the customer to buy one?
Cheers!
They're not supplied aftermarket with shock pumps, and from meory you don't generally get them with shock pumps with the bike either, although it's been quite few years since I worked in a shop so this may have changed.
I didn't get a pump when I bought my five (fox forks & shock).
Will ask my mate in the trade... no you don't get a pump with any of their brands only one you do is with high end Treks which is a wrench force/trek one, shops may chck one in if you ask nicely at time of purchase 😉
I bought a set of Fox floats at the start of this year and didn't receive a pump. I don't think they include one anymore.
Ok, cheers all.
I've had fox forks with the pump provided in the past, when buying fork-only off-the-shelf, or as a Rr shock on a frame-only purchase.
But that was several years ago.
Right, off to browse interweb shops for shock pumps then ...
Did you not think to perhaps keep hold of one???
Have a look on the classifieds they often turn up on there cheap.
