Hiya - buying a new XT groupset that comes with x2 180mm rotors and post mount calipers. It's to go on a new Commencal META HT frame that is IS and a 2015 Revelation fork.
What adaptor(s) do I need if any ?
I'd hope the front would be a straight fit but that's only if I had a 160mm presumably ?
Thx!
Correct, you will need a front 180mm shimano adaptor
[url= http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747 ]Like this.[/url]
Plus one for the rear [url= http://www.chainreactioncycles.com/shimano-mount-adaptor-rear-post-to-is/rp-prod13749 ]like this.[/url]
Thank you very much cdoc. Ordered from High On Bikes at £6 each and £5 off by also buying tubes that I needed at the same price as CRC...
So net cost for both adapters £7...
Man maths at its best !
Shimano brakes used come with a 180 (+20mm) PM to PM on the front and 160mm IS to PM rear. Do they not anymore?
There's half a chance they'll come with the adaptors you need, but you won't know till they arrive.
Ah OK thx!
