Quick Check ~ Goodr...
[Closed] Quick Check ~ Goodridge Hose Set up on Hope Mono4 Caliper
 P20
[#3058141]
Just a quick check before i head to the garage and start fiddling with brake fluid, etc.
The correct order for parts on Goodridge hoses and Mono4 calipers:
Outer towards caliper...
Nut/screw thing
o ring seal
bango
o ring seal
caliper
Do you put in any brass washers anywhere? I thought there was one between the caliper and the banjo? 🙄
Posted : 17/08/2011 3:43 pm
IIRC there's a copper washer goes between the banjo and the lever
Posted : 17/08/2011 3:48 pm
 P20
Cheers. The Goodridge page seemed to suggest that there was no brass washer at the caliper end, but the bike currently has one which probably explains the leaking. I had just assumed it was some way of making sure the two surfaces fit
Posted : 17/08/2011 3:51 pm
This may help
http://www.diaryofamountainbiker.co.uk/goodridge_brakeline_replacement.php
Posted : 17/08/2011 3:53 pm
 P20
Cheers uplink, thats what i wanted!! 😀 😀
Posted : 17/08/2011 3:57 pm
