Quick brake questio...
[Closed] Quick brake question
[#11282245]
New 35mm SIDs, minimum rotor is 180mm, so presume no adaptor needed and just bolt brakes straight on? If so is there a particular bolt I should be using (Deores)?
Ta.
Posted : 05/07/2020 5:03 pm
No adaptor needed if you're running 180 discs...
Adaptor needed if you're running 200+.
Is that what you meant?
Posted : 05/07/2020 6:52 pm
You can't fit 160, you can fit 180 without an adaptor, 200 will need an adaptor.
Normal brake mount bolts. M6x20 IIRC, should have some with your brakes
Posted : 05/07/2020 6:55 pm
Cheers guys, yeah running 180. Need to get some bolts. Do they need the half-dome bits that help it to centre, or just the washer?
Posted : 05/07/2020 7:51 pm
No. You don't need the dome washers. Standard M6 cap head bolts will do it.
Posted : 05/07/2020 8:10 pm
Why do you need new bolts? You should just be able to re-use your existing ones.
Posted : 05/07/2020 8:19 pm
