Quick alfine 11 spo...
[Closed] Quick alfine 11 spoke length question
[#3092970]
I have done the calculation but it would be great if someone could confirm it. I make it 256/7mm. Alfine 11 spd 32 hole hub, laced 3 cross on to a Mavic XC717 Disc rim with an ERD of 541mm, flange dia is 92.6mm, spoke hole is 2.6mm, offset is 29.5 and 24mm. Inout much appreciated.
Thanks.
Posted : 29/08/2011 9:50 am
 Del
can't comment on your numbers without the hub dimensions, however i'd consider ( having built an alfine 8 wheel last year ) going 2 cross. the angles that the spokes end up at relative to the rim, as a result of the hub's flange diameter, can be quite large. if i was going to build another i'd go two cross. HTH.
Posted : 29/08/2011 10:10 am
As above, as an Alfine 8 owner (similar flange diameter and spacing) both my friends with an Alfine and I have gone for a 2 cross setup due to the large flanges.
I originally built it 3 cross without thinking about it and it was so wrong I bought new spokes and rebuilt it!
Posted : 29/08/2011 10:21 am
Funny, I built an 8 spd alfine with 3 cross and no problems, thanks for the inout though. Never built 2 cross!
Posted : 29/08/2011 12:25 pm
