Hi there,
I'm wondering if anyone has read the warranty or had experience of a 180mm rotor on the on-one 29er carbon fork? Was there a lot of flex - was it worrying?! I'm going to be using a BB7 cable disc.
Also, is there a weight limit on the fork? Might use it with a BOB trailer.
Thanks.
No weight limit as I am aware but i am pretty light.
I have a 180mm BB7 on the front and there is a little movement but not as much as the Pace forks (or some steel ones I have had!)
SSP
brant has always said no weight limit and 180's are fine. i rode a carbon 29er for a while and i am pushing 14stone, doing drops and small jumps and was fine. never had noticable flex or flutter under braking. the fork does deffo move fore and aft but in a helpful shock absorbing way unless you whang it into an object real slow in which case it has the unnerving feeling of tucking underneath you and then springing back! i assume all carbon forks do this tho. kind of miss it now i have suspension.
