Who knows what happens when you over-tighten a Mavic axle trying to remove that last little bit of free play from the free hub?!
I DO!!!
GRRRRRRRR
That is all.
Does anyone know where I can get a new axle for a set of Mavic cross max SSC SL's?
I don't know exactly what year, but they look are these:
[url= http://www.mtbr.com/cat/tires-and-wheels/wheelset/mavic/crossmax-sl-disc/prd_365258_157crx.aspx ]Mavic SSC's[/url]
Dom
Any mavic dealer will be able to order the right bits in, all they'll need is the number off the rim (by the little bar code)
That gives all the details required to make sure the right bits arrive.
Thanks goldenwonder.
Need to find my nearest Mavic dealer now!
Sweet, Primera cycles to the rescue!
I really should have Identified the preload adjuster and tightened that rather than the bleeding axle!
