having recently purchased a revelation dual air i have noticed when pumping up the fork there is some oil residue left on the pump and the fixing of the fork. Is it normal to get a bit of oil leaking out i have never owned an air fork before cheers
Posted : 10/02/2009 9:00 pm
My mates and my own Rebas did this - its residual lube oil from the air chamber. You can pop some back in if you think you have lost too much.
Posted : 10/02/2009 9:20 pm
cheers matt it doesnt look a lot just didnt know if it was normal cheers
Posted : 10/02/2009 9:21 pm
Is it from the negative valve on the bottom of the leg? If so then turn the forks upside down when pumping up this chamber and the oil won't drip out.
Posted : 10/02/2009 9:37 pm
