Q's for FTM ca...
[Closed] Q's for FTM carbon owners
[#4361878]
Heard somewhere that you need a shadow rear derailer for this frame to clear the chainstay pivot, is this correct?
I know the front derailer needs to take the cable from above ie top pull but can you use either a top clamp or bottom clamp model
Thanks
Posted : 14/09/2012 12:13 pm
I think you're right, you do either need a Shimano shadow rear mech or I was using a SRAM one which are fine also.
Can't remember what front mech I had on. It was an SLX of some description.
Posted : 14/09/2012 12:34 pm
Mine has a high clamp - I've just looked and think a mid clamp will be fine, but not a low clamp. I also have a shadow rear mech.
And wow, it is light!!
Posted : 14/09/2012 12:40 pm
No to low clamp front mechs
Posted : 14/09/2012 6:44 pm
