Q/R- 20mm front hub...
[Closed] Q/R- 20mm front hub conversion
[#1100830]
Hi
I have a no name 20mm front hub. Does anybody know if the hope conversion kits for Q/R fit any 20mm hub?
Dan
Posted : 04/12/2009 12:33 pm
The diameter will fit but there's no reason to assume that the bearing spacing is the same so it might fit but it might not give you the 100 mm drop out spacing you need.
Posted : 04/12/2009 1:06 pm
So if i measure the hub body width and it's the same as the hope or another brand I can use their kit? I'm just assuming the conversion kit slides in where the 20mm axle goes. If so then as long as the adapters plus the width of the hub body = 100mm then I'm good to go? Bet it's not that easy!
Posted : 04/12/2009 2:44 pm
you'd be better off comparing the measurements between bearing faces.
Posted : 04/12/2009 2:56 pm
Nice one Onza. Thanks for the advice.
Posted : 05/12/2009 11:07 am
