Putting an FSA chai...
[Closed] Putting an FSA chainset on a Shimano BB: Will I die?
[#6521530]
(always wanted to do that ^^^)
Yeah so I removed to old XT chainset and popped the FSA one in. It's a dual setup as opposed to the 3x XT so it took a little fiddling to get my 3 speed shifter set up (sacked off the granny option and used middle and big with some adjustments to the big ring limiter and cable adjust on the shifter)
Seems solid - no play or clunks, everything torqued up/greased and pedals on. Little ride around the garden and nothing alarming happened.
Will I die when I'm miles away from home?
Posted : 01/10/2014 7:52 am
Nope.
I run an FSA Moto G (think they are GAP or Gravity now) on XT and it's fine, apart from the ground bits of the spindle being a bit tight on the top hats, but then that's what 4lb lump hammers are for.
Posted : 01/10/2014 8:10 am
Yes, and the wildlife will feast on your corpse. 😀
Posted : 01/10/2014 8:43 am
Goody. That will get rid of some of the belly fat I just can't shift. Result.
Posted : 01/10/2014 11:02 am
you will die,
well maybe not die, but no matter how much I tighten in my FSA comet set keeps working loose!
Posted : 01/10/2014 11:09 am
threadlock? (not MY thread though...)
Posted : 01/10/2014 11:22 am
