putting a singlespe...
[Closed] putting a singlespeed cog on a Pro II hub
[#1426649]
i've got a Pro II which is an out-of-the-box 9spd one with an aluminium freehub
just wondering if it's possible to run it singlespeed without making a mess. i expect a regular 1/8" steel cog would dig itself into the freehub fairly rapidly. has anyone tried it?
does anyone do singlespeed cogs which have a nice wide spline to spread the load? i.e. a bit like an XT cassette spider
Posted : 19/03/2010 2:04 pm
On One did one
on one groove armarda have a wider base, as do CK and surly, iirc...
i have a 16t groove armarda for sale, for what its worth... email in profile, i'm away this weekend though.
Posted : 19/03/2010 2:06 pm
Surly, Chris King both have a wide base
superstar do some which look really wide.
Posted : 19/03/2010 2:07 pm
Surly ones have a pretty wide base when compared to the cheapo pressed ones... but it is still only about 5mm - Andel do one as well - available from [url= http://www.velosolo.co.uk/shopsingle.html ]VeloSolo[/url] and [url= http://www.charliethebikemonger.com/userimages/procart5.htm ]Charliethebikemonger[/url]
Posted : 19/03/2010 2:08 pm
My 9 speed cassette dug in nicely on my Pro II so I just thought **** it and ran a standard SS cog and spacers on mine. So far so good!!
Posted : 19/03/2010 2:12 pm
 devs
Personally I'd get the steel freehub. I got one cheap off here. Next best thing would be the groove armada but even that will dig in a bit.
Posted : 19/03/2010 2:14 pm
cheers fellas. have checked all those out
the superstar one (dare i say it) looks ideal as it's 10mm wide, although i might have preferred a steel one for longevity. also i vowed never to give him any more money
does anyone know how wide the chris king ones are? might be worth the investment
Posted : 20/03/2010 10:08 am
Can only really comment on the Surly ones, but they are fine to use on alu freehubs.
The main issue with them digging in, as this can happen with a cassette too, is getting the lockring at least 40Nm (that's bloody tight btw, if you don't have a torque wrench!!). That way, the lockring and spacers together with the single cog are cinched up super-tight and not relying on the splines on the freehub body to hold them in place.
Posted : 20/03/2010 10:21 am
Used Chirs King and Surly (both about 4-5mm) on ally Pro2 and Pro3 and both been absolutely fine, in fact better than most cassette's i've used.
This is for proper honking up Dark Peak inclines too.
Posted : 20/03/2010 11:09 am
I use a superstar wide spline one and its fine , have just ordered another one actually in a different size
Posted : 20/03/2010 2:22 pm
I'm using a groove armada on an alu pro2 freehub body and its fine. I'm a 14 stoner too.
Posted : 20/03/2010 3:20 pm
