My Pushloc has packed up and they seem to be difficult to find, can I replace it with a Poploc? The Forks are Rockshox Reba Teams 100mm.
Tom
I'll be interested in this discussion too as mine is broken too.
Checked with my lbs and they said either will fit or the new one will fit too too, can't remember what it's called though?
However they said there's none in stock with the Sram at the moment so I'm still waiting....
Pushloc only pull 10mm of cable. Poploc pull 17mm of cable.
A poploc might work but i'd advise using the blue cable wheel from a poploc damper too to avoid the poploc trying to over-pull the current blue cable wheel.
Thanks guys, I think I may have sourced one the same as mine but hope the thread helps Jonny, btw is that Jonny in NZ, if so, Hi!
Tom
