PUSH tuning...
[Closed] PUSH tuning...
[#1340089]
£175 + P&P instead of £85 + P&P... it's going to add up pretty expensive once I add a lockout (to replace the remote poploc)....
Convince me?
Posted : 18/02/2010 10:30 pm
you'll only notice it if you push (geddit) them hard, and a remote lockout? come on.....
basically it sorts the high speed rebound out, like I say, you'll only notice if you ride em fast
If you think they are working well for you now, you will probably not notice the difference, however if they spike badly and go crazy in the rough stuff, time for some PUSH lovin.....
Posted : 18/02/2010 10:49 pm
Yar, sounds like it sorts out the rebound damping when you're further in to the stroke, which is where the Revs feel like they've suddenly gone too hard.
Aside from magically adjusting the spring rate beyond the dual air capabilities it sounds like a winner. But an extra £90...
I do like to go fast but am a bit chicken sometimes so erring not at the mo... unless it's that good.
As for the remote lockout - I have the bar mounted poploc but it doesn't fit with my mudguard and I don't like the extra mess of cables. Simplify!
Posted : 18/02/2010 11:01 pm
Its not when you are further in the stroke, its high speed rebound (i.e. when the fork legs are moving quickly) - so it helps with lots of big hits, square edged hits etc.
Posted : 19/02/2010 10:48 am
works very well on long DH rocky bits, such as the lakes or peaks.
Posted : 19/02/2010 11:47 am
