Purgatory 2.3 - Rim...
[Closed] Purgatory 2.3 - Rim Poll
[#5646940]
Curious after yesterdays thread.
So I'll start :
mavic 719's and tubes
Posted : 30/10/2013 8:40 am
719 and tubeless.
Posted : 30/10/2013 8:57 am
B.O.R XMD 388
Tubeless
Posted : 30/10/2013 8:59 am
Flow and tubeless.
Posted : 30/10/2013 9:07 am
Flows & tubes.
Posted : 30/10/2013 9:09 am
 cnud
Flow Ex Tubeless
Posted : 30/10/2013 9:10 am
819 tubeless.
Posted : 30/10/2013 9:11 am
Crest & tubeless - big one though
Posted : 30/10/2013 9:17 am
DT ex500 tubeless.
But also using an Eskar(which is bigger) tubeless on an XM719, no burps or noticeable tyre roll.
Posted : 30/10/2013 9:41 am
as an aside, in what dimension is an 819 bigger than a 719 ?
Interesting replies so far, keep 'em coming !
Posted : 30/10/2013 9:43 am
Wtb i23 tubeless
Posted : 30/10/2013 9:45 am
Spank spike 35 and tubeless, come up huge.
Posted : 30/10/2013 9:49 am
 sv
Flow & tubeless.
Posted : 30/10/2013 9:57 am
Easton EA70 XCT & Tubeless
Posted : 30/10/2013 9:59 am
Tubeless on Easton havoc UST (23mm).
819 is the UST tubeless version of the 719 - it's the same width.
Posted : 30/10/2013 10:03 am
719s tubeless here - on both my FS bikes.
Bike one has Conti Rubber Queens. I'm Purgatory curious, so this thread is relevant to me.
Bike two has Spesh Storm / Captain.
Posted : 30/10/2013 10:09 am
Is anyone running a butcher front, purgatory rear? Is this a good idea?
Posted : 30/10/2013 10:12 am
P35 tubeless. 29" 2.2 and 2.3 Purgs (look about the same casing size to me).
They're not quite as big as some suggest, a step down from an Ardent 2.4 and a bit smaller than a 2.2 RQ, so about right for the listed size. Great wet-weather all rounders.
Posted : 30/10/2013 10:14 am
Yes, butcher front, purgatory rear on Arch Exs tubeless. Amazingly grippy and relatively fast-rolling set-up for most conditions. Although the butcher isn't as bulbous as the purgatory if you like your front bigger than your rear 😀
Posted : 30/10/2013 10:15 am
Butcher front, Purg rear on Mavic Crossrides, ghetto tubeless using Gorilla tape.
Posted : 30/10/2013 10:16 am
wilko99 - Am considering the butcher/purg combo (both 2.3), but interested in your comment on sizing, are you saying the equivalent butcher comes up a little smaller than the purg, by how much would you say?
Posted : 30/10/2013 10:50 am
719. tubeless.
Posted : 30/10/2013 10:51 am
Rear on Traversee EL and tubeless. (and a 2.35 Nevegal on the front).
Personally I suspect that if people didn't know they had narrow rims, most wouldn't notice any tyre roll... Maybe we should blind test this and run around swapping wheels on people 😉
Posted : 30/10/2013 10:53 am
Tubeless purg on rear and butcher on front. Cross trail wheels impressed so far maybe a bit of roll on purg but on rear and does not bother me. Butcher is v good IMHO and paid 52 quid for the pair not far off 1 maxxis
Posted : 30/10/2013 10:59 am
Butcher and purg with tubes on roval traverse on my 13 stumpy evo. Stock setup basically.
Posted : 30/10/2013 11:07 am
Hard to quantify without having the bike in front of me. Maybe a couple of mm across the widest part of the tread? Not sure on height. I'm going to have to check now, just out of sad curiosity 🙂
Posted : 30/10/2013 11:10 am
Butcher vs Purgatory:
http://www.reifenbreiten-datenbank.de/reifen-Specialized-Butcher-26x2.30.html
http://www.reifenbreiten-datenbank.de/reifen-Specialized-Purgatory-26x2.20.html
(The Purgatory 2.3 is on the same size carcass as the old 2.2 version - marketing! 😉 )
Posted : 30/10/2013 11:14 am
Superstar EVO's, EN321's, tubes, Minion/HR.
Posted : 30/10/2013 11:19 am
Perg & flow ex with tubes, no probs.
Posted : 30/10/2013 11:31 am
Arch, tubeless
Yes. Yes.
If this is in relation to tyres rolling on rims, my feeling is it is a side effect of tubeless - there is less there to be solid. Someone posted a video of their tyre rolling around on tubeless recently, mine aren't that bad but it is noticeable, more so on low speed techy stuff where balance is more important. my Arch rims are relatively narrow though.
Posted : 30/10/2013 11:47 am
front, purg 2.2 on 721
Rear, eskar2 2.3 on 721
Both tubed, no issues.
Posted : 30/10/2013 11:51 am
And the award for not reading the op goes to…
st colin - Member
Posted : 30/10/2013 12:02 pm
My 717's are looking to be a bit thin 😆
Posted : 30/10/2013 12:22 pm
 mboy
Purgatory 2.3 on Pacenti TL28, currently tubed cos I've been too lazy to set it up tubeless!
Nice profile to the tyre though, and grips very well!
Posted : 30/10/2013 12:44 pm
Tubeless on flow and P35. Might try stretching it across a dually at some point.
Posted : 30/10/2013 12:48 pm
I got a pair of Purgs because the front Butchers weren't available at the time. More than happy with them, but just ordered a Butcher to go on the front out of curiosity more than anything else.
Posted : 30/10/2013 2:22 pm
 SOAP
Mavic 317s tubeless with insulation tape and tubed valves.
with Stan's fluid.
Flows tubeless with fluid.
Both inflated with a joe blow first time.
Bloody great tyres!
Posted : 30/10/2013 2:30 pm
WTB Frequency I-25 Rim 29" 2012 Purgatory F & R tubless
Posted : 30/10/2013 2:36 pm
Purgatory 2.3 front, Captain 2.2 rear, on crests.
(No noticable difference in size between the two BTW.)
Sorry, forgot: Tubeless.
Posted : 30/10/2013 2:39 pm
ARCH EX tubeless.
Purg 2.3 front(new) purg 2.2 back(old)
The new 2.3 seems to come up massive compared to the rear. Great grip no roll or burps. run at 28psi +-
Posted : 30/10/2013 2:49 pm
 SOAP
En321's not 317's
Posted : 30/10/2013 2:54 pm
st colin - Member
Where's my prize? 😆 Sorry, been a long day so far!
Posted : 30/10/2013 3:09 pm
 mmel
EN521's, tubeless captain at the rear and a purg out front with a tube at the moment
Posted : 30/10/2013 3:16 pm
FWIW I will be using tubes..... can I get away with 717 rims yet?! 😆
Posted : 30/10/2013 3:34 pm
great feedback, thanks all. I was starting to wonder if these tyres were a bit big for my 719's but it appeears not 🙂 My Nobby Nics can stay on the shelf till Spring.
Posted : 30/10/2013 6:07 pm
