Had an email through earlier, always fancied giving a dropper type seat post a go, for £60 I reckon it might be worth a punt. Anyone have any thoughts on them?
I got that too. Quite fancy it but it implies it also acts as a suspension seatpost which I really don't want!
It appears to be the same as the one from America for 30 dollars or something. Was mentioned here a while back, but didn't have very good reviews. Can't remember it's name, will have to have a look.
i take it that 27.2 is the only size?
Is it the same as this?
http://www.mtbr.com/cat/controls/Seatpost/sette/ryde-st-850/PRD_418242_141crx.aspx
I've got one of the Sette ones and it works fine. It looks a ringer for the i850.
You don't notice the suspension in the post as the action is pretty stiff. They do feel a little heavy and they do seem to have a running in period but otherwise very good.
Stuart
Yeah I believe 27.2 is the only size at the moment.
Well I've ordered one, worth a go. Will report back on how I get on with it...
DrP has one, used in the Alps recently. Seems like a very good bit of kit for the money.
It really only gives a 'suspension seatpost' effect of you sit on the nose of the saddle. Sitting nearer the back usually locks it out (Flex I guess)
For the money it's as good or better then a Gravity Dropper, IMO and if they did a 30.9 I'd have one. (I don't like shimmed posts after cracking a Ti frame because of one)
You can get them from Europe for something around £50 delivered I think.
Seriously, can we get some link action here please!
i would link but I'm aware that most have just had breakfast and would probably like to keep it down....
Nevermind, found on leisure lakes and ordered.
You can get it for 45 euros if you look about
[url= http://www.heli-bikes.com/Shop/product_info.php?info=p2867_Kind-Shock-KSP-850-Adjustable-Height-Seat-Post-27-2mm-365mm.html ]http://www.heli-bikes.com/Shop/product_info.php?info=p2867_Kind-Shock-KSP-850-Adjustable-Height-Seat-Post-27-2mm-365mm.html[/url]
shims are fine, as long as you get good 100mm long ones.
I had a bounce on one at leisure lakes and it looked awesome for the money
Both my bikes are 27.2 so I might stick a spare saddle on it and a) swap it between bikes and b) save it for nice days as it'll no doubt keel over in one wet ride like most do...
As PP states, I beasted mine around the alps for a week, with little problem.
It's a pretty device (as they should be i suppose) as it just needs to go up and down when I want it to!
Good points are:
It's dirt cheap compared to the others - there's no ignoring that fact
It's one of the only ones that fit my 27.2 bike
It's got the lever under the seat - i still think it's the neatest and a very user friendly design.
It's infinitely adjustable (i.e. can be stopped anywhere along it's uppy downy length
Bad points:
Not as light as others
Does have a bit of play, perhaps more than Andy's gravity dropper, but un-noticeable when riding.
Is like an adjustable suspension seatpost i.e. it can bounce up and down about 20mm, but this only happens if you sit on it in the 'line of travel'. As my seatpost is quite layback, you have to sit abnormally on the nose for the seat to squich down - in normal riding it just doesn't happen.
Would I reccommend it to a friend - definitely, It's dirt cheap compared to others and does it's job well.
I'm gonna attempt to take it apart for a grease and polish, so hopefully no high pressure bolts will burst through my face....
DrP
Thanks for the review DrP, I look forward to trying mine out when it arrives, of to Afan next weekend also so that'll be a good test for it...
Good. Let's all hope that happens then....
DrP
It'll last 6 months. Wish I had £60 to blow on cheap toss.
[b]rolfharris [/b]- Member
It'll last 6 months. Wish I had £60 to blow on cheap to.
Just like the £250 posts then. I know what I'd rather spend. Might give it a go a some point.
Got one from xxcycles about 3, 4 months ago. Not super plush but serviceable. Does what it says, but it can get a little sticky on the way down and take a couple of goes to drop - probably off centre weight. Comes up every time. Easily worth £60 but not a £150 plus job - good job their only charging £60 then.
IGM - did you find service details on the web?
If not, could you briefly let me know of any pitfalls to avoid when unscrewing the post.
Also, how do you 're-pressurise' it on putting it back together?
DrP
DrP - Member
Good. Let's all hope that happens then....DrP
Thankfully you won't be there to see it - and as a bonus I wont have to look at your ugly seatpost whilst I have crap on my face, or at any other time, ever!
The artist - wtf does it matter what your bike looks like? its a machine for riding not a fashion statement. I bet you'd rather be covered in dog poop than have mudguards as well
here here TJ....
as for a rack?
it would end in a ban i reckon....
TandemJeremy - Member
Here's my last bike.
It's cheap crap - I wouldn't put it on any bike even my 12 year old mishmash hardtail. Oh, and it's fugly.
Bargain, does it work on air or spring?
It's air then it's probably a poor lockout that gives it the 'suspension post' action, rather than it being intentional!
I actually made my own adjustable post for the sum of £3 from parts from my local tip! It worked very well, untill it bent!
It's about time someone built one for a reasonable price! Specialized's one is £250!
apologies then artist
No worries teej
Wow, mine's arrived already! Nice one Leisure Lakes! I had a parcel turn up at work and I couldn't figure out what it was, only expecting a Macbook and some tees at the moment - it just seemed too early to be the seatpost already esp as it was listed as coming soon!
Ok, out of the box, it's heavy, let's not pretend otherwise!
Looks - not bad actually, remains to be seen how it looks on the bike but it's a country mile better looking the the GD posts and it's fairly discreet (red handle aside).
I have no idea what the action is like purely because there's now way I could compress it on arm strength alone anyway!
Sadly all my bikes are dead right now awaiting some part or another but will feed back and include pics once I finally get it fitted! AT this rate it'll be going on the singlespeed first as the Five needs a new bearing kit...
Drop it round mine Gary and I'll test it for you 🙂
>It's cheap crap - I wouldn't put it on any bike<
LOL - said the man with the green bike, brown forks and gairish black fenders
The post isn't exactly a work of great beauty either but then any black post is going to be fairly indiscreet. If it works and its cheap I can't really the see the problem
Discreet that is 😉
i wish you could still buy those bd
Judging by how battered and scraped the post is on that green spesh, the i850 would be a visual upgrade!
From what I saw of DrP's post recently, they are anything BUT crap!
Cheap? Oh certainly. But they are well made and work well too.
How other compaines can get away with charging £150-£200 for 2 tubes and a spring is beyond me, frankly.....
maybe the extra money goes into removing the bonus inch of sus travel?
Or into marketing BS?
still dont really understand these things. £60-£250 to save you the hassle of getting off your bike for a sec, undoing the QR dropping your seat and then tightening you QR again.
balmy!
or making things look pretty
But even the £250 ones don't look "pretty".
balmy!
God forbid any of us want to actually ride nonstop!!!!
God forbid any of us want to actually ride nonstop [i]and can't do that without endless changes to position on the bike.[/i] 🙂
i wouldn't mind one for riding in the pyrennees/alps when you don't know how long the downhill is or what it will be like. It's an arse stopping to drop your saddle only to find the track just goes round the corner then uphill again!
