PSA? Zee drivetrain
[Closed] PSA? Zee drivetrain
Yeah OK that's a good PSA
Posted : 28/11/2014 11:27 am
A banger of a PSA. Excellent work
Posted : 28/11/2014 11:28 am
The chainset and cassette weight more than the sun and SLX is only £30 more on merlin (flog the LH shifter, front mech and rings for £30)?
Posted : 28/11/2014 11:44 am
Great for a budget DH/FR build though - as long as you've got normal width BB shell.
Posted : 28/11/2014 11:55 am
That'll do nicely, thanks OP, that's Christmas for myself sorted.
Posted : 28/11/2014 12:14 pm
Wonder if it's a short cage mech though. It says "wide ratio(n)" on it. If it's a short cage then you can "only" go up to a 40T with an extender.
Posted : 28/11/2014 12:20 pm
Zee mechs are all short cage. They're different angles for narrow or wide range cassettes.
Wide ratio is designed for 11-36 but it seems to work on 11-40 but as you've said, not 42
Posted : 28/11/2014 12:23 pm
Cheers!
Just need to decide if shorter cranks are worth it 🙂
Posted : 28/11/2014 12:27 pm
As nemesis says above, all Zee mechs are short cage. The only difference between the models is the "bracket axle unit", the bit of metal that bolts to the mech hanger on the bike.
Posted : 28/11/2014 12:28 pm
already seen this and decided to step away. Please stop hyping it.
Posted : 28/11/2014 1:32 pm
There's that new one-up cage doo dah that'll fix it isn't there?
Posted : 28/11/2014 2:55 pm
Yep but then you're kind of making a more expensive mech though I've heard it does work well.
Posted : 28/11/2014 2:56 pm
aye. it is cheaper to just stand up 😆
Posted : 28/11/2014 2:58 pm
Thanks. Ordered.
Posted : 28/11/2014 9:04 pm
