PSA: Worth it for t...
[Closed] PSA: Worth it for the rings alone..........
[#4828292]
http://www.chainreactioncycles.com/Models.aspx?ModelID=46021
Cheap, square taper, fill your boots.
Tim
Posted : 03/02/2013 9:42 am
 nuke
Good one...and currently only 6136 in stock 😯
Posted : 03/02/2013 9:45 am
Better be quick then :O)
Posted : 03/02/2013 9:46 am
Make that 6135.....
Nice PSA, thanks 🙂
Posted : 03/02/2013 9:57 am
False economy.
You'll buy these, use the rings, then buy and build a single speed around those two shiny crank arms, which you'll then replace with something more bling at the end.
Don't feed the N+1
Posted : 03/02/2013 10:02 am
Good PSA, but nobody noticed the £25 Deore HT2 ones they sold a few months ago..... I did. 🙂
Posted : 03/02/2013 10:20 am
they must've all missed your PSA, peter
Posted : 03/02/2013 10:48 am
Cheers for the heads up there Tim, I've ordered one for the bike I'm slowly building up for my 14yr old son. It's from CRC though so I look forward to it arriving on my desk in a box the size of a wardrobe 😉
Posted : 03/02/2013 11:03 am
Morning Slugwash dear boy. I hear you've bumped into a wee Scottish fella on the roads down your way!
Should be in Charlestown the second week of Easter. Fancy a beer? I might be able to squeeze a bike in the car given a small amount of encouragement.
Posted : 03/02/2013 11:30 am
Cheers timbur,
Ring perfect for my marin rebuild..
Posted : 03/02/2013 11:40 am
Good work mate.
That Marin needs retiring. She's an old girl now!!
Posted : 03/02/2013 11:47 am
good only if you need it, other wise expensive and wasteful for a 22t (cranks bin, 40+t bin, 32t bin)
Posted : 03/02/2013 11:50 am
... a wee Scottish fella desperately trying to keep up with me during his Puffer training on Dartmoor.... 😉
I'll probably be in Lewes around Easter so could do a South Downs ride instead/as well 🙂
Posted : 03/02/2013 12:00 pm
strange thing to post. 😕
Needing new rings for my work bike, they will do just dandy, if fact its a sq taper bb so i'll just put the chainset on.
Posted : 03/02/2013 12:01 pm
lol
it's only cheap if you need that exact thing, not many I know running 22/32/42 9 speed. Don't know anyone on Sq taper at all. If you are stock up though.
Posted : 03/02/2013 12:04 pm
My SQ taper xt BB has been on my work bike for yrs and has been flawless (kiss of death now)
Posted : 03/02/2013 12:07 pm
fair enough (I see the who else has one post) I generally never got on with shimano rings either 🙂 there was a PSA on SLX shifters a while back, having tried some I could see why they were cheap too.
Posted : 03/02/2013 12:12 pm
Drop me an email. First week we're here, second week we head SW.
Posted : 03/02/2013 12:15 pm
Burden, i have another Eldridge that has had a slightly better life..
Posted : 03/02/2013 1:34 pm
Not difficult. That first once was baggy.
Posted : 03/02/2013 1:55 pm
False economy.
Don't feed the N+1
This is so true. But I can't help it.
Posted : 03/02/2013 2:40 pm
What length bb axle for these cranks 113mm?
Posted : 03/02/2013 10:09 pm
Just check if you can that the rings are replaceable as I bought a set of cranks with replaceable rings (photos showed replaceable also) and the cranks turned up as spot welded ones.It was also with CRC, however in their defence when I contacted them they refunded me and told me to keep them FOC.
Edit looks good
Edit again just ordered cheers
Posted : 03/02/2013 10:17 pm
 nuke
[i]What length bb axle for these cranks 113mm?[/i]
Probably. But then maybe not. I base it more on the frame than the cranks. For example, on my Inbred 853, 113mm was specified for the cranks but I found 118mm better suited to the frame
Posted : 03/02/2013 10:30 pm
Looked it up from techdocs for somebody a couple of days ago, think it was 118 or 122.5 depending on chainline requirements, feel free to double check.
Posted : 03/02/2013 10:37 pm
I thought the race face respond double chainsets we're a good deal, y'know, if you have some kind of 21st century bike...
Posted : 03/02/2013 10:54 pm
cheers coatesy
Posted : 03/02/2013 11:21 pm
Ah, this could be what I'm after for the little lady's bike, however...
The rest of the drivetrain is 10spd; if I swap the 10spd rings across to this crank, will the shifting work okay?
Posted : 04/02/2013 9:37 am
