You've just used this as an excuse to show off a picture of your lovely bike Tracey 😃
It not mine, will be eventually passed down to me or her sister 😉
Her dad will get the tyres
Anyone recommend some crank boots that will fit?
ogden
Member
I was going to ask that. Don't race face do some for their carbon cranks? Wonder if they fit...
Our carbon cranks are fitted with the SRAM ones as in the above photo. Cranks are on their third season of racing. I hate to think what they would look like without the boots.
Lol,I didn't think to see if sram do them!
About £12 delivered for the boots.
Anyone found them cheaper?
Ours came from CRC when they were selling them cheap. Bought spares just in case
Thanks Tracey, I'll keep googling.👍
https://www.ebay.co.uk/itm/161858722452
These look like the right ones.
I'm going to wait till next month so I don't feel like I've spent even more money than I needed to.
£9.64 delivered on eBay, best I can find so far.
Don’t the Raceface ones fit OK? I’m sure I got a couple of sore sets somewhere from the various warranty sets I had over the years
We tried the Race Face on my X0s and they were too big. Allowed dirt to get down the sides of the boots.
I haven't ordered stuff for a while... is it normal now for Wiggle to be so haphazard with their pictures/ descriptions/ specs or did someone just get over excited when being told to get web pages up for a big box of OEM stuff?
Sram crank number one described as non-Boost arrives with a Boost chain line ring. No problem I thought the X01 is showing as even cheaper and exactly what I want (non-Boost)... only to receive an X1 alu crank, rather interestingly also including a pressfit Sram BB which I most definitely didn't order.
Is this a one off for them?
No this isn’t unusual for them at the minute.see the rock shox Yari psa from a couple of weeks ago where most people ordered 29er forks and received 650b instead.contacted them about the pair I ordered and there response was to offer me a gift voucher if I kept them,the forks don’t fit what good is a gift voucher
The above eBay link for the SRAM boots is good, mine arrived today from them. Would not use carbon cranks without them.
They are definitely carbon arms under closer inspection from a magnifier despite my initial worry.
Hopefully my slik x01 graphics will arrive by the end of the week to jazz them up a bit also.
I must say the gxp spindle does look quite weedy compared to the dub crank I removed.
That's a shame if it isn't a one off. The response I have so far is I can return the X1 "sent by mistake" (X01 ordered remember) for a refund and can buy the same X01 I ordered in the first place in a new order but now for double the price. No exchange or swap allowed unless the item is faulty FFS
oldtalent
Member
Cheers mate, I'll order those now you've confirmed they fit the carbon cranks.👍
Well I nipped into garage and tried my spare Raceface crank boots...fine to me, same as my descendants:
Edit! FFS for some reason the forum is now not accepting images!
The hope adaptor looks like a pair but do I only need to use one to be able to use my hope threaded BB
Or can someone recommend a threaded gxp BB?
Also is the ring 12 Speed only or can it be used with 9, 10 11
You use both parts of the Hope GXP adapter, press into both sides of the NDS.
Uberbike do a GXP external bottom bracket
race face boots fit the X1 arms perfect, about £6 with my order,
although i'm awaiting my secon dpair of X1, CRC claim they split my order of the 2 crankets, got one parcel, i rang cust services and they sent me a tracking ref, its not moved since 11pm at crc warehouse on the 8th april, i have a feeling i'll be back on the phone, as my delivery note states 2 items, (no mention of box parcel1 / parcel2)
I had an Uberbike ceramic GXP bb and it lasted about a month (heavy winter use) so if it were my money I’d buy the hope adapters, 2 minutes to fit and a much better BB.
The chainring is an eagle chainring albeit I believe these to be backward compatible so will work on 11 speed
You can get a gxp adapter for like £1.50 on ebay
Some one has my order! Ordered these on the 5th still waiting for delivery though the tracker says dispatched on the 8th ... oh well..
So, I have mine now.
About 570g with the ring.
Quite pleased to say the least - thanks to jamj1974 for the PSA.
Can the SRAM X-Sync rings be run with 10-speed chain?
I've seen it suggested that the tooth profile only works with a SRAM chain. Is that so?
JP
HELP HELP
I bought these for my new (to me) frame that has a Hope BBPF4130SS BB. just building now and they don't fit. Have a live chat on CRC and was linked to buy the BB I have that disnae fit.
Is there an adapter or do I need either new BB or new cranks?
That’s because you have purchased a 30mm BB and these are GXP which is 24mm tapered to 22mm (?)
What frame are you fitting them to? Do you have a link we can then tell you what BB you need.
Looks like you are pf41 which is this
But with the GXP adapters fitted to NDS bearing which are:
https://www.evanscycles.com/hope-truvative-gxp-bottom-bracket-conversion-kit-EV208097
It’s a pivot Mach 6
Bb was in frame when I received it,
My x0 cranks are not boost so I stupidly thought all boost were the same size.
If your X0 cranks fit then just swap over the boost chainring.
It’s the spindle that’s a different diameter for the Bb mate. Your X1 cranks came with a boost ring so whack that on you Xo1 cranks is they are 30mm spindle? Or buy the correct Bb for your new cranks
If it's a bb30 bottom bracket you can buy gxp adaptors like these
https://www.sigmasports.com/item/Wheels-Manufacturing/BB30-to-SRAM-Adapter/TXB
Ok,
Can you point me to the hope BB I need?
So had a look at Pivots website (shocking by the way) looks like it’s a Pf92. So as I linked in my earlier post you need this
As well as the Hope GXP adapter caps which push into the non drive side bearing
Hah. I went to fit mine tonight, weighed them and they're 2g lighter than my XTR M970s that they were going to replace. Or slightly heavier, if I fitted crank boots.
TO EBAY!
Thanks russyh.
Anybody run 10 or 11 speed on the chainrings? Need to change so have a choice but like the look of those steel rings.
Love it, let’s buy carbon cranks and stick a steel ring on it 😀
Lighter than alloy cranks with steel ring!
@ Tracy - I **think** those adapters won't work in a 92mm bottom bracket shell?
