PSA- Specsavers lau...
[Closed] PSA- Specsavers launch Puma prescription cycling specs.
[#6952848]
http://www.specsavers.co.uk/glasses/puma-sun-rx-05?sku=25672329
They are a wrap around style with Rx insert, mirror dark tint, orange blue blocker, and clear lenses.
I made up a pair last week, great on the road bike, fine for 40mph downs, with no eye watering, or vibrations.
Then used the orange lens in Cwmcarn, perfect to increase the contrast in under cover low light woods and trails. Had a few (slow) offs, on the technical climbs, but the specs stayed on.
The insert sits quite flush to the outer lens so they don't sit too far out, and the insert isn't the usual 10p size round eye, but a tapered rectangle shape, so gives a much better field of vision.
Really pleased with them, just wish the dark lens was a brown tint instead of grey.
Posted : 24/03/2015 10:55 am
Any chance of a real photo - instead of their flattering renders?
Posted : 24/03/2015 11:44 am
[i]Jason
active 1 day, 23 hours ago[/i]
obviously an excellent product - thank you so much
Posted : 24/03/2015 12:12 pm
Above has to be an error... Look at the posting history??
Posted : 24/03/2015 12:16 pm
Indeed all that states is that he was last active just under 2 days ago, but registered and been a rather active memeber for a lot longer.
Posted : 24/03/2015 12:17 pm
Quite a sensible price too, It's about time I had a new pair of specs. Wonder if they can me had on the 2 for 1 offers.
Posted : 24/03/2015 12:21 pm
sorry - apologies 😳
sorry - apologies
Should have gone to Specsavers
Posted : 24/03/2015 12:43 pm
Nice one ndthornton
Posted : 24/03/2015 12:48 pm
Rx insert?
Utter Crap. I'm ooooooooot.
Cilaryblue will put a nice proper wrappy lens into most cheap/copy sunglasses frames.
Posted : 24/03/2015 12:53 pm
[i]Cilaryblue will put a nice proper wrappy lens into most cheap/copy sunglasses frames[/i]
This. My 8Euro, ahem, 'Ferrari' frames have a Cilary Blue photochromic prescription lenses. About £50 all in
Posted : 24/03/2015 1:04 pm
About to try Ciliary Blue with a pair of Bolle safety specs.
Asked them if they could glaze Bolle Spiders and was told "no".
I'm trying just sending in another style to see what happens.
If it works then it will be FAR cheaper than the specs in the OP but obviously only with one tint rather than the 3 above.
Si
Posted : 24/03/2015 1:14 pm
Another cilary blue recommendation here.
Ordered my cheap sunnies from the site below. They say in descriptions if they are suitable to cilary blue.
www.i-sunglasses.com
Posted : 24/03/2015 1:46 pm
Example here
http://www.i-sunglasses.com/Choppers-Padded-Sunglasses-8CP905-Black-Clear
Posted : 24/03/2015 1:57 pm
Oh now THAT is a good link, cheers!
Posted : 24/03/2015 2:01 pm
The Speccies ones are £99 with the Rx insert , and will work with 2 4 1, so you can get a pair of normal specs for that price.
I've got a wrapped photochromic prescription lens pair I use, but in woods I find them too 'shadowy', especially in winter as the cold makes them quite dark.
I prefer these but will use both that's all I'm saying.
Posted : 24/03/2015 3:29 pm
Last time I got glasses from Specsavers I got them to put clear lenses in a pair of their wraparound sunnies. They were horribly distorted till they reduced the prescription a little to take into account the curve of the lense. Happy with them now.
I'm slightly shortsighted.
Posted : 24/03/2015 3:36 pm
antigee - Member
Jason
Posted 3 hours ago #
Posted : 24/03/2015 3:50 pm
What Rx? I'm +5 and my Rydons have interesting optical qualities due to the curvature. The brain does however adapt pretty quickly.
Posted : 24/03/2015 4:38 pm
 aP
Your optician might want to look at using Rupp+Hubrach if you have high prescription in a high base lens to correct the inevitable distortions of the lens orientation.
Posted : 24/03/2015 4:42 pm
Mine's only -2.50ish.
You can get lenses specially optimised, so the Rx is altered to account for the wrap, not sure of the cost though.
Edit- too slow, Norville will certainly be able to do as well.
Posted : 24/03/2015 4:50 pm
Try Bolle KIDS glasses for cheap fit for purpose. You look a bit like Chipps, but otherwise ace. I got 1 clear, 1 sunglasses.
Our local opticians did me 2 pairs of
prescription glasses (about 0.75 strength) for 140 quid. Very happy with them. There are many styles.
Posted : 26/03/2015 8:22 am
Inserts are shite, avoid at all costs, they just steam up (so you've four sides to try to clear) and eventually break off there rubberised mount. My local optician just glasses a set of normal sport glasses with UVPolarising fornot a lot, compared to the mainstream shops/fashionable branded sunnies
Posted : 26/03/2015 11:47 am
 aP
Inserts are shite
I knew I'd been doing something wrong all these years, I guess I'd better give up cycling, anyone want to buy my bikes?
Posted : 26/03/2015 12:14 pm
If there a rubbish as the inserts your using, then no thanks 😉
Posted : 26/03/2015 12:31 pm
 aP
8) I find my inserts don't mist up...
Posted : 26/03/2015 12:32 pm
Mine (adidas something of another) did, and it was a nightmare to clean all 4 sides when your all sweaty, then the rubberished frame became unbonded, and no one could supply a glue that would bond it back together.. They cost me a small fortune, and were really rubbish, I can't recommend anyone try the same system even from another manufacturer
As I say (well I tried to say...) a local optician was able to supply a generic sports frame and glaze them with reactor light lenses for not a lot. This might not be the case for some ppl's prescriptions, but I'd recommend it over inserts any day of the week... which is surely what ppl come here for.
Posted : 26/03/2015 12:49 pm
First issue with Ciliary Blue - the box they send (postage paid inc in price is too small for the glasses I am sending (either my old pair for reference or the new pair).
So if using them it's worth factoring an extra bit of cost and faff to sort your own box and pay the extra for a 'small parcel' rather than 'large letter' stamp.
Si
Posted : 26/03/2015 2:59 pm
As I said, I like them, no problems steaming up unless I stop after a really tough climb, but never whilst riding. Been out in them for a few of hours on the road, and the same on mtb. If you do stop for a chat or whatever, you can just take them off and wave around a bit, or man up and keep riding.
Posted : 26/03/2015 7:26 pm
