PSA - really cheap ...
[Closed] PSA - really cheap 160mm Pikes £449
[#5891539]
I really want some pikes but can't find a set of 150 mm in budget. I did find these 160mm for pretty cheap though.
http://www.freeborn.co.uk/rockshox-pike-rc-26-dual-position-air-160-tapered-15mm-black-2014
Someone must want a bargain.
Posted : 26/01/2014 12:33 am
£599.98 at Tweeks Cycles and show in stock
Posted : 26/01/2014 1:04 am
That's well outside of my budget but thanks mate.
Posted : 26/01/2014 1:08 am
£500 off zee Germans with free postage. 😉
Posted : 26/01/2014 1:26 am
Rob which site mate? Thought I'd looked at them all and found none that low.
Posted : 26/01/2014 1:28 am
I,ll mail you..
Posted : 26/01/2014 1:38 am
Cheers mate
Posted : 26/01/2014 1:41 am
Got my reverb off them Mosey and there spot on to deal with.
Posted : 26/01/2014 1:45 am
 mmel
Get the 160mm and change the air spring to 150. Loco was saying they're due in stock soon and should only be around £30
Posted : 26/01/2014 8:51 am
That is for the RC version, not the RCT3 version, if its bike-discount you are referring to.
Posted : 26/01/2014 10:26 am
I'd spend a bit more and get the RCT3 version too based on others recommendations of them... and i've very nearly pressed the buy button several times.
I fancy the RCT3 160 dual position version... am I right in thinking these could be wound down to anything between 130 and 160mm, so I could set them up so that max travel is 140mm for example, and adjust to 160mm for days out at the trail centre? 😆
Posted : 26/01/2014 10:53 am
Alternatively, he Revelation RCT3 150mm dual position forks are just over £400 at bike24.com
Posted : 26/01/2014 11:07 am
Ah I'd not noticed these were the rc version.
Creamegg I'm pretty sure it's just two set positions. You push down and lock it at say 130mm then release back to 160mm.
That's what my revs did anyway.
Posted : 26/01/2014 11:16 am
Has anyone weighed a set of new Pikes yet?
Posted : 26/01/2014 11:19 am
from RS website...
It changes your fork’s travel up to 30mm
to me that offers adjustment of anywhere between 0-30mm. Anyone else able to confirm?
Posted : 26/01/2014 11:33 am
Dual position with 30mm difference.
Unless they changed it from last year.
Posted : 26/01/2014 11:35 am
Yep. My 26" 150mm RCT3 Pikes with a 195mm steerer weighed 1801g.
In comparison the Revs they replaced (Tapered 150mm RCT3 195mm steerer) weighed 1727g.
Posted : 26/01/2014 11:47 am
Dual position means just that
not U-turn
Posted : 26/01/2014 11:59 am
I need 150mm, someone has found me some though.
The RC just looked like a bargain for someone.
Posted : 26/01/2014 12:02 pm
https://www.cotic.co.uk/order/components/
Cotic £550 for RCT3 150mm Pike
sorry out of stock boooo
Posted : 26/01/2014 3:31 pm
