PSA - Edge 800 soft...
[Closed] PSA - Edge 800 software update: Ver 2.2 out today
 fbk
[#2678387]
As above.
[b]Changes made from version 2.10 to 2.20:[/b]
Added setting to turn on 1 second recording in Settings > System > Data Recording.
Fixed an issue that could cause large jumps in position and distance.
Added Last Lap Power data field.
Fixed an issue that was causing ANT sensors to not pair as expected.
Added a setting to enable a prompt to recalculate during navigation.
Courses are now usable with GPS turned Off and a connected ANT+ Speed sensor.
The Virtual Partner can now be manually synchronized by pressing and holding on the Virtual Partner graphic.
Fixed a speed zone field display issue.
Improved course navigation.
Fixed issues viewing an activity in progress from the history menu.
Fixed issue with some Mac users not being able to connect to device without resetting the timer.
Fixed some display issues when using a weight scale.
Fixed an issue that could cause distance to not accumulating after switching bike profiles while the timer is running.
Fixed a few issues while editing workouts and a display issue while doing a workout in night mode.
Fixed a display issue while doing a workout in night mode.
Improved elevation calibration when manually setting device elevation.
Fingers crossed it'll solve a few "issues"
Posted : 20/04/2011 12:00 pm
Fanks dude 🙂
Posted : 20/04/2011 12:01 pm
cheers for the heads up!
so will the elevation thing be sorted now? my current readings from rides on the websites (bikehike, gpsies etc etc) are some 500ft less than the reading of the edge 800 🙁 )
Posted : 20/04/2011 12:09 pm
 DT78
How do I get the update on my 800? Does it autodownload next time I use garminconnect or do I need to do something about it?
Posted : 20/04/2011 12:10 pm
Thanks!
Posted : 20/04/2011 12:14 pm
 fbk
Oscillate Wildly - do you mean elevation gain? I think there'll always be a discrepancy between the GPS and mapping software - the mapping software will take the GPS course and map it directly onto topo maps, measuring every change in elevation along it (including any corners cut & any small changes); the GPS uses barometric info as well as the GPS so will probably iron out some of the more subtle changes in altitude.
That's my understandingt anyway as all the GPS units I've owned have given significantly lower elevation change readings compared with memorymap etc.
Calibrating the unit with a point of know elevation will help to some degree though I think.
 fbk
DT78 - the easiest way is to download the "Webupdater" software from the Garmin site then just connect the Edge and run the software
Posted : 20/04/2011 12:15 pm
Download Webupdater to you PC, plug in your unit to pc USB, run Webupdater and follow instructions.
Edit: damn too late 🙁
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Posted : 20/04/2011 12:16 pm
fbk - Member
yeah sorry elevation gain -
i used to have a dakota20 and that was only ever about 5ft out in elevation gain from that of the websites....
i dont understand how it works on this now? if i start at 0ft elevation gain, and ride the route and get to 2330 ft, its physically reading the gain as i do it...
doing it on the websites (and of course my dakota20) and its about 1850ft so somehow ive gained 500 feet of elevation on that ride??
one of them is wrong - its surely to coincental that dakota 20 and ALL of the websites states the 1850ft gain?
its just when i keep a check on the edge 800 as its gaining height (i have this on the screen) i never ever notice it jump from say 100ft to 300ft instantly in error, it seems to go up steady and as and when im climbing?
Posted : 20/04/2011 12:20 pm
is it not automatic the altimeter?
i have never set anything up like that on my edge800? perhaps thats why then?
Posted : 20/04/2011 12:21 pm
 fbk
That does sound a bit odd - I've never had mine [u]over[/u] estimate altitude gain! I can't explain that one I'm afraid.
As for the calibration, you're right, it does automatically do this using GPS data. I think it does help with accuracy if you manually enter a point of known altitude as it calibrates the baromatric altimeter and helps varify the GPS altitude (which I believe isn't as accurate as in other dimensions...but I could be wrong!)
Posted : 20/04/2011 12:29 pm
it is very strange - and also to confirm its wrong i just remembered ...
when i upload to garmin connect the route ive just done, there is an option/button for 'correct elevation gain' or something similar...
on this too, it then loses about 500ft of elevation gain somewhere, and thats from a garmin based product 🙁
very strange, the dakota definitely never used to do it, as id often plot the routes beforehand, thus already knowing what the elevation gain was going to be, and low and behold it was always there or there abouts....certainly not 500ft out 🙁
still love the device though, its a mint bit of kit!
Posted : 20/04/2011 12:32 pm
 DT78
Ok thanks for the info will have a go this evening.
Posted : 20/04/2011 12:47 pm
Thanks for the heads up on this. Finally they have given us 1 sec recording instead of the smart recording. Hopefully get back some off-road accuracy...
Posted : 21/04/2011 6:56 pm
