PSA DVO at Soprt Pu...
[Closed] PSA DVO at Soprt Pursuit
[#11284913]
Link for anyone who is interested. Forks and droppers.
Posted : 07/07/2020 8:21 am
As always, some good prices, but light on detail. From reading that, I can't tell if it's the 27.5+ version from reading tyre size, or the normal 27.5" version as defined by the travel range.
Posted : 07/07/2020 8:51 am
Cheers Jordan. A Shame they are 27.5 🙁
Posted : 07/07/2020 9:09 am
It says
Throw a 27.5” wheel and a 2.8-3.0 tyre on and enter a world of ultimate traction! Just make sure you have at least 6mm of clearance between the top of the tyre and the bottom of the arch, just to be safe!
so presumably is the 27.5+ version. Although won't all Boost 27.5 forks take plus tyres?
Posted : 07/07/2020 9:55 am
 Del
I can’t tell if it’s the 27.5+ version
I would then assume it's a regular 27.5. forks suitable for 27.5+ are generally just referred to as 29ers.
Edit: hadn't read Hamish's bit. Good luck.
Posted : 07/07/2020 10:03 am
But the travel is quoted as 170mm which is only available on the 27.5". The 29/27.5+ is only 160
Posted : 07/07/2020 10:09 am
I just had a look, it says 27.5 repeatedly in the spec. Including on "wheel size".
The thing about taking 3in tyres is weird though, that could be a mistake.
Specification:
Travel: 27.5 = 140-170mm
Crown Offset: 27.5 = 44mm Offset
Axle to crown: 27.5 = 572mm at 170mm travel
Stanchions: 35mm Tapered Alloy
Wheel Size: 27.5
Axle: 15 x 110mm QR
Weight: 2100g
Steerer Options: Tapered Alloy
Lowers: Magnesium, Disc only
Posted : 07/07/2020 10:11 am
