Thanks! Ordered yesterday and already here! These are to replace the wheels that were on my base model Levo for a few years and then on my Moxie for the last 18 months (I’m amazed they’re still in one piece!) I’d been planning to get some XM481 on Hope hubs but wasn’t sure on spoke count. This has saved a load of thinking and even more money!
I’ve got EX511 on Hope with 32 spokes on the Levo so I think these should be good on my 160mm hardtail - probably with inserts because I don’t like worrying about dents or pinch flats.
The specs on crc show the only difference is the freehub as far as I can see. Both based on a 350 hub, so not sure where that info about two halves is from. Any pointers?
Each wheel name usually includes either 'Dicut' or 'Spline'. This refers to the interface between the hub and the spoke. Here's DT Swiss's explanation:
Dicut DT Swiss’s lightest, stiffest and most aerodynamic hub and spoke system, aimed squarely at competitive road and track riding where speed is the overwhelming priority, uses custom Nailhead spokes that can hold much higher tensions.
Spline DT Swiss’s classic straight pull system, a great balance between stiffness, comfort, low weight and easy serviceability, ideal for everyday road or mixed terrain use and uses readily available standard straight-pull spokes.
Google suggests SPLINE just means straight pull spokes are used (an abbreviation of straight pull line I suppose)
Edit: beaten to it ^ too slow on the google
Thanks all. So maybe the only difference is that one is XD and 6-bolt, and the other is Microspline and CL. The RRPs are different which also threw me.
yeah but you were quick with the code which is what counts!
I suspect they are the same wheel, maybe with different freehub. Maybe stock brought in at different times, hence slightly different descriptions. But who knows! CRC seem to be experts at having the same item listed several times at the moment eg M6100/m6120
