Possibly worth a punt. 24l reservoir that runs at 120PSI. 2.5HP electric motor. Assembled and looks good to the untrained eye. Only bit I need now is the connection from a "euro quick coupling" to a valve stem. Anyone done this?
I bought one last time and just cut the end of and stuffed a cheap brass pump chuck on, works well and I'm very pleased with it
Cheers OP I might have a look tomorrow.
Can you explain the connection thing, are they a different type than 'standard'?
Didn't quite understand kilos solution? Anyone else bought one and sorted a connection to a tyre?
I got a convert connector from a hydraulic pneumatic supply place.
Aldi, etc. usually do a kit of air tools for about 15 quid when they have the compressors. There's a tyre inflater in there (needs an adaptor for presta valves though).
Edit - An 'accessory pack' like this:
(Looks like it's got a presta adaptor ...)
Curly hose, blow-off gun and tyre inflator are the useful bits.
The one i bought from aldi had a presta adaptor with.
Is this compressor at all Stores at the mo?
Not noticed in any of the Aldi emails I've had recently.
No compressors in my local store so will have to wait for next time.
No rush. 🙂
If you ask your local helpful store manager they sometimes have sale stuff like compressors and hose kits in the store room.
Good tip ta, was in a rush today so will revisit next week.
The hose kits + accessories are reduced in the Lewes store at the moment.
Tim
Will one of these be suitable for inflating tubeless tyres?
Yup.
It's about all they're good for, not enough airflow for spraying or powering tools but they'l do for infrequent or quick/easy jobs like inflating tyres.
bella - MemberDidn't quite understand kilos solution? Anyone else bought one and sorted a connection to a tyre?
Sorry typed in a rush. What I meant was mine came with one of those air guns with a pressure gague for doing car tyres, I just lopped the end of that off and replaced it with a bike chuck to do my wheels and tubeless rather than use the fiddly little adaptor that came with it.
We have one of these mounted on the wall in the garage, never failed to inflate any of our tubeless tyres. Not a bad price new but dirt cheap when they were selling them on.
I had a version of that that B&Q (in a different colour / branding) used to sell a while back. Handy wee things, not least because they are light. Only down side is the hose starts to decay, bubble and burst over time and is permananty attached so can't be replaced (at least without dismantling the machine). Mine was more gaffa tape than hose after while.
