decent German made hubs (my Tune i think? the rear free hub is certainly Tune)
http://www.ebay.co.uk/sch/velomanuk/m.html?_nkw=&_armrs=1&_from=&_ipg=200&_trksid=p3692
Claiming to be 16 holes, which I'm sure is a typo, but you never know...!
i guess he only counted one side,
Yep, so do I, as I've never seen a 16 hole disc hub, but you ne'er know!
Tune hubs any good then?
QR only? Add another £20 each end for the adapters, still a good price. Been running a set since May without issue, early days though
They do gave some bolt through rears for sale
Mega cheap price compared to Tune hubs, looks like you can get the adaptors from Clee cycles and the German sites
There was a 135mm qr rear/15mm front set but they went quick
There was a single 15mm black front, I bought that, rude not to for 45 quid
what are the weights like? vs pro2s
[url= http://bor-germany.de/en/product/98-bor-md7-rear ]http://bor-germany.de/en/product/98-bor-md7-rear[/url]
226 grams for the rear, so very light.
I have run a set for a few years and they are spot on. Well worth it a this price too. Exceptional hubs.
sooo tempted, just to check, just need to get endcaps to swap to 15mm, 142x12?
and says they are good for all mountain ,
still ok for enduro radness?
Yep, just swap the end caps, I couldn't resist bought a set & end caps from bike24. Can't suggest I ride enduro radness but they survived my inept general trail riding (aka blunt force) so far & built up as a nice light wheelset with LB rims
Rear adapters here...
Sold individually so a wheel set would be 4 caps...
http://www.bike24.com/p255161.html
Front may be on there too, I only had a quick scan through
What am I missing here, £90 for a rear hub doesn't exactly sound cheap?
entirely bizarre that they sell them as all separate pieces, why would you only buy one side? The front comes as a [url= http://www.bike24.com/p255151.html ]set from bike24[/url]
Edit: Nope not cheap compared to say Shimano, but compare them to a similar decent cartridge hub, say the Hope Pro 2 or DT Swiss 240 they cheaper & lighter
The full RRP.............
http://www.stradawheels.co.uk/product/tune-king-kong-mtb-hubs/
Well I've ordered a set, got a new lb rim so looks like I'll have a nice new lightweught wheel soon. !
sooo tempted, just to check, just need to get endcaps to swap to 15mm, 142x12?and says they are good for all mountain ,
You wont be disappointed kimbers. I have ridden these over a couple years including several alps trips, bit of racing and one to two rides a week with uplifts now and again. Got through three rims on the rear over that time, but still on the first set of bearings. I'm guessing that's down to the the tolerances / way they are made. Quality hubs for sure.
The only down side is that the freehubs aren't cheep.
I'd read on the net these were a little fragile and the free hub can't be user serviced? Is that old info?
These are the older generation Tune hubs as far as I am aware. Not the spontaneously combusting generation but not the latest either. At those price they are a steal. You can pull them apart just fine. I think the non-user servicable aspect comes from Tune (or maybe Poshbikes) being paranoid about anyone swapping bearings themselves even thought it's pretty much the same as any other hub.
Not the case, as DanW said you can pull them apart without tools, relube the bearings and go from there. If they do need bearings its a case of drift out and new ones in. I think you'll have to be fairly careful tho as there is not a huge amount of material / free lips to press against.
i had a Tune MK 20mm when i did the Mega - not much different to these imo
my 15mm front hub turned up today - 116g on the kitchen scales
edit: 32h as well 🙂
Converting qr to 15mm on front hub, do the adapters just pull off?
Yes, I had to use pliers, but wrapped a bit of rag round to prevent scratching
Ta, a bit more persuasion needed then 🙂
My rear is needing a bearing change, I think as there's some play
I'll have a look this weekend and see if a regrease weill sort it, dies anyone know of a manual?
Not any better than hopes, for bearing life then,p probably less as they've not been ridden that much this year reallt, I don't jet wash either but they have seen an awful lot of mud
bump?
I emailed them and they said were working on the manuals, but they did also say.."B.O.R uses Tune Freehubs and Tune-Plugs (for either quick release or thru-axle). Therefor the Tune manual would be appropriate"
